Preferred splice technique?
I definitely need a chisel tip for my iron, at the very least. Using 60/40 rosin core.
Frankly, I'm having the most success in directly melting a blob of solder onto the connection, then getting that to flow into the joint. I thought it was the iron, but it's probably the fact that I'm soldering in-situ on the bike and don't have enough hands to steady the wires as they sit while holding the iron and the solder, so I'm not getting solid contact. Getting the blob on there first results in better transfer of heat from the wire to the solder, and gives me a hand to keep the wire in place as I apply the iron.
Definitely total hackery. :) Next time I will do a layout board and assemble a proper harness off of the bike.
Flugtech, I was worried about the grease working its way between the elements of the contact, since it's an insulator, not a conductor. (Late-breaking news to me...I always assumed it was conductive!) But today I found that a really thin layer doesn't seem to present much practical of a risk for that.
