Jramos13
If there was show called my build from hell my bike would be on it.... :'(
Anyway after sorting out my electrical and carb issues, a new problem arise
On idle im running on the LH side only, the RH only will fire if i hold the plug cap close to the plug but not when put it in completly. If i try to accelerate with the plug put in i can hear the RH carb choking and the bike would stall if i dont let go of the throttle, if i accelerate really slow then it will accelerate fine, the rpm hangs on the way down.
I already tried swaping the coils, plugs cables and boots from RH to Lf and i get the same result so the coils are good, i have Viets ignition the rh is a bit earlier than the lf but he told me that its normal and they do em like that for easier starting
