Single front fork raised 20 cm higher than other one...need some help!
keeper_o1
hey guys so the bike is a kawasaki kz 750 e2 model the fork started rising overnight, and has steadily increased. have tried tightening, doesn't want to budge. May be a dumb question but any help would be fantastic. thanks guys.
Ummm is it covered in oil or something?
The triples should absolutely not allow that to happen. Horribly dangerous....
Are the triples and the forks the same diameter?
My guess is that either the triple or the tubes are not stock and do not match. Oil or no oil that should not happen if bolts are tight
I don't see any bolts in the pinch clamps on the upper triple. Are those air fittings on top of the upper fork tubes? Have you checked the air pressure in them? Could one fork have more pressure in it than the other?
lingo yes they are air fittings, but we deflated both (with only a little air coming out) and figured that the air pressure had nothing to do with it.
so it happened while the triple was off. i had taken it off to attempt to clean (as you can see poor job). i've tried to tighten the bolts to no avail, not really too sure where to go from here, except for a complete fork dismantle?
thanks again guys.
hillsy, i would assume so, i have never rode the bike, the forks felt good when i bought the bike, nothing that would point to the RHS missing its spring?
Dont assume anything on a bike you've never ridden.
Prop up the front end and take off the fork caps.
