sl350 swingarm on cb350 - question about shocks
Rimmy
The SL350 swingarm is longer and wider than the CB350 swingarm. How do people who've done the swap line up the shocks? Are they offset or something?
Can you measure side by side? How much different is the SL swingarm? I know the rear of the SL frame is different, but was not aware it was wider.
Hopefully XB can comment. He is familiar with the SL and CB.
CB - 225 mm inner axle spacing
SL - 245 mm inner axle spacing
CB - 220 mm between shock mounts, 18 mm wide shock mounts
SL - 238 mm between shock mounts, 18 mm wide shock mounts
I'll have to check with a plum line but it looks if I use the upper shock mounts like normal, the lower mount (if I use a shock with a bottom eye) will line up right next to the bottom mount. I'm not sure if I can safely just use bolt to connect the swingarm shock bushing mount to the eye of a shock.
