CB - 225 mm inner axle spacing
SL - 245 mm inner axle spacing
CB - 220 mm between shock mounts, 18 mm wide shock mounts
SL - 238 mm between shock mounts, 18 mm wide shock mounts
I'll have to check with a plum line but it looks if I use the upper shock mounts like normal, the lower mount (if I use a shock with a bottom eye) will line up right next to the bottom mount. I'm not sure if I can safely just use bolt to connect the swingarm shock bushing mount to the eye of a shock.
