Slow return to idle
cb350greg
Active Member
1973 CB350G.
after the bike gets up to temperature, it takes a while for it to come down to idle, and even then its alot higher than what the idle was originally set at. its something related to the right cylinder/ carb. thats about as much as i know
bike sat for a while before i bought it, carbs were all gummed up. took them all apart, cleaned them, blew compressed air through everything. also installed new floats. found a tear in the right diaphragm and replaced it. did not fix it so i switched the diaphragm/ slide with the left one just to make sure i had installed it right. still no good
thought it could be a leaky intake rubber or gasket so i sprayed WD40, carb cleaner, etc on it and did not get a change in RPM. switched it with the left one just to make sure. still no good.
any ideas? keep in mind, it only does this when hot.
I know you said you sprayed it with wd 40, but it still sounds like an air leak.
its the right carb/ cylinder thats giving me trouble, so i switched the intake boots and if it was a leaky boot, then the problem should've switched sides. and it didnt'
What about the carb mounts themselves? Did you switch the throttle cables too? Might be the sleeve heating up and "squeezing" the wire inside.
what do you mean carb mounts? the only thing between the carb and the engine is the rubber intake boot and a gasket. i took the boot and gasket from the left side and swapped it with the ones on the right.
not the cables, i can see them snapping back down against the stops.
i appreciate the help though, please keep throwing ideas at me.
someone i work with suggested a bad head gasket, but i never heard of one causing these symptoms and another guy said bad coil. dunno about either of those though
im sure a bad head gasket would be leaking oil as well. While a coil shows symptoms after warming up, thats not your case. A bad coil shuts down after heating up.
If its not an air leak, it has to be in the carbs. Are they still in sync?
they're close, but do need some tweaking.
BUT if i pull the plug on the left so its only running on the right, it still does it, so i feel like that eliminates carb sync as a possibility
checking the compression tonight, just cause
Well Greg, im pretty much out of ideas. But if i think of anything else ill let you know.
checked compression even though i don't see how that could cause it to act like it is.
125 on the right, 120 on the left.
also swapped carbs from left to right and the problem followed the carb.
i'm really tempted to just order a pair of Mikunis from Dime City... only thing holding me back is that i just dropped $150 on new diaphragms and floats :(
I can probably get you a deal on some used carbs if you want them. Or buy the VM30's and give me a deal on those diaphrams! ;D
hmmm tell me more about these mikunis...
i still have one brand new diaphragm, unopened. we might be able to work something out.
where in PA are you anyways?
