cb350greg
Active Member
1973 CB350G.
after the bike gets up to temperature, it takes a while for it to come down to idle, and even then its alot higher than what the idle was originally set at. its something related to the right cylinder/ carb. thats about as much as i know
bike sat for a while before i bought it, carbs were all gummed up. took them all apart, cleaned them, blew compressed air through everything. also installed new floats. found a tear in the right diaphragm and replaced it. did not fix it so i switched the diaphragm/ slide with the left one just to make sure i had installed it right. still no good
thought it could be a leaky intake rubber or gasket so i sprayed WD40, carb cleaner, etc on it and did not get a change in RPM. switched it with the left one just to make sure. still no good.
any ideas? keep in mind, it only does this when hot.
