small CL 360 project
Hey guys, thank you all very much. All I can say is I must be one hell of a photographer. LOL. alright, alright, I confess. I paid Jay to say that... Well, not really. But I'm hornored by the comment Jay, because there are so, so many cool builds here. I must admit though, I'm feeling you must be a little sheltered. ;)chuckle. Just kidding. I guess we all have our favorites, I just never expected to be on someone's favorite list. :o Again, thanks.
I'm still knee deep in wiring and I have a question. Since I'm kick start only, do I still have to run everything through the starter selonoid? I'll take a look at the wiring schematic tomorrow but I know that I'll get just as much out of it as I did the first time I looked at it (big fat 0). Like I said, I'm pretty lost when it comes to this stuff. I'm pretty good at soldering/heat shrink and have a bit of common sense, but that's about it. Thanks in advance for any help. Troy
The CJ360 has no starter or solenoid. It is wired without them from the factory. The shop manual has a section for the CJ wiring diagram. I plan to use the CJ wiring diagram for my CB360. I found a starter plug. Here is the part# 32951-310-810. May be hard to find. I found mine on eBay. Hope this helps haven't tried the wire job yet or looked at both side by side. Nice work by the way.
Dan
Awesome idea on the brake pedal-- I've been thinking of the best way to do super-cheap home-brew rear sets... I'm definitely stealing that idea!
Another question-- how are you mounting your turns or are you even running them? Looks like you did the same thing that I did on the back of the frame, which doesn't leave a convenient spot for the turns.
Dan
That is great info on the CJ and also the starter plug DP! Thank you very much! Good luck on your project. Do you have a thread yet?
Sausage,Turns are not going back on. The are required here if they came on the bike, but its pretty laxed around here. i know quite a few guys not running them. I'm leaving the wires just in case. Before I decided against them I was looking at welding small tabs just below the frame. Something tucked away. Sorry I'm not much help.
I've wanted to ask about your avitar. Its very cool. If you don't mind me asking, who is it and is there a story? Troy
I wish there was a better story-- I read Max's 4q Conditioning blog... tons of awesome photos of old panheads & knuckles, skateboarding photos from the 60s... just really cool stuff. Yanked that photo from there, cause it kindof looks like me and my dad looked when we were kids-- except I didn't have a motorycle, I rode BMX bikes with a playing card in the spokes.
http://4qconditioning.blogspot.com/
I like the pic sausage. You can tell the guy really likes his bike.
Got some more stuff done today. I hope I can say I'm finished with wiring (thank god). Turned out pretty good. I may want to add a couple more running lights and I still need lights for the plates. Should be easy to add when I make the bracket for the plates. Painted my old headlight bucket and it turned out real nice (I know I say this way to many times, but man I love this epoxy paint!) Painted both the bucket and retainer ring silver. replaced the old high beam indicator with a new LED. Headlight is just stuck in the bucket. I still need to buy the bolts. But you get the idea. The paint has tons of tiny metalic but at the same time its kinda flat. I really dig this flat silver color.
Messed around with paint scheme. After seeing how the bucket looks I'm leaning real hard towards doing this. Let me know what you guys think (couldn't match the color but its the same as the frame color. It's a flat silver with tons of tiny tiny metalic. The 200 tank has the pad up the middle.
no black, everyone does black. i would say do a deep red/rusty red, or a robins egg blue. both those colors would go really well with the frame
I like the grey one minus the checkers, but I think orange or copper would look real sick. Also did you have to replace your throttle and clutch cables or did you keep the old ones?
Thanks very much for the response guys! Looks like 4-3 for the black. I was leaning so hard for the silver for a couple of reasons. First, you just don't see to many all silver with black highlights and second, I'm falling in love with this flat silver. I think it hides very well and i can lay it down. I really like the durability of the epoxy paints and that is why I was sticking with black or silver. I was also thinking like JRK but inverted. the all silver would make the black pop. Anyhow, since I'm on the fence its going to be ....drum roll.......
Black. Again, thanks for all the opinions. Keep in mind after I see how the black turns out I reserve the right to re-shoot it silver. ;)
Hey hanly, for now I'm using the old cables. They suck. Way too long. The throttle doesn't want to return right. I've re routed and re routed but nothing seems to help. As soon as I get the finances I'll swap them out.
have you lubed the cables? alot of time the cables need a bit of lube on there and will work fine... the cable being long should not affect its return
As for progress. I'm waiting on clutch push rod parts. the "screw" as its called in the man. is bent all to hell and doesn't allow the bearings to push the rod properly. As soon as It somes in things should roll pretty quick.
I received my VW mufflers. I left the pipes a little too long and the wrap needs to come up higher on the muflers. The tapper just looks too small when the wrap starts where it does. I'm hoping I can cut some of the tapper down and take the wrap a little farther out. I did brush the chrome and plan to clear coat it. Just something else for me to re-do. I'll also probable paint the bracket silver.
Yeah, I lubed um up and they feel good until I put the push cable on. It feels like it is binding somewhere. There is really very little room for extra cables. I really think that shorter may help, but who knows. Hey man, gotta run I've got to be at a meeting in 15 mins. :(
