Re: Used Banshee Pma - XS - 90 Shipped
The Po had screwed it to the case near the three Oem Banshee moutning holes.
A mounting plate would be ideal, which it doesnt have.
You could use your current ignition system and coils along with your battery.
A new rectifier/regulator to handle the constant amps though.
Or
Get a new rectifier/regulator, high output coil, pamco "if you dont already have e. ignition" and sparx capicator for batteryless operation.
So to use it at a minimum would be a new rec/reg and making a mounting plate out of some thin aluminum.
Or do the Po method of drill tap to the case itself which I wouldnt do personally.
