SOLD-Used Banshee Pma - XS - 90 Shipped
taggat
Coast to Coast
90 bucks shipped, insured with tracking.
It takes a bit more effort to mount it than the other kits but works just as well.
Its been sold.
Re: Used Banshee Pma - XS - 90 Shipped
Just thinking of what else I'd need for this to mount to my XS. Would need one of Hugh's regulator/rectifiers I think - anything else? Might be keen to pick this up. Help me fill in the blanks so I can convince myself I need it :)
The Po had screwed it to the case near the three Oem Banshee moutning holes.
A mounting plate would be ideal, which it doesnt have.
You could use your current ignition system and coils along with your battery.
A new rectifier/regulator to handle the constant amps though.
Or
Get a new rectifier/regulator, high output coil, pamco "if you dont already have e. ignition" and sparx capicator for batteryless operation.
So to use it at a minimum would be a new rec/reg and making a mounting plate out of some thin aluminum.
Or do the Po method of drill tap to the case itself which I wouldnt do personally.
