starter problem
FEARtheBEARD
my starter in my cb200 winds and solenoid works but it only seems to ingage when it wants to, is there any way of fixing this, i think it is the clutch in it but not sure, help a brother out haha
Most likely ur starter clutch is wore out. I have a cb500t and it has the same problem. Ive gotten use to just using to kick starter i cant find the starter clutch parts for mine.
yea thats what i figured i mean she starts in one kick haha and its 37 years old i just wanted the electric starter so i could say it works
The cb200 works with a spring operated clutch and some pins. This system is, after 37 years at it's end.
You can relatively easy (depends on your skills and tools) replace the worn parts. Thats the only way to do it.
Part numbers 11, 12, 22 will do the trick as far as i know. You'll need 3 of each.
Depending on what you're going to find in the engine you might need to order more parts.
http://www.cmsnl.com/honda-cb200b-usa_model1005/partslist/E++04.html#results
and do i have to drain the oil to get to the clutch, just wondering before i take the outside plate off and have oil go everywhere
okay so i took it apart today and watched to see what happened and it seems like the starter dosent have enough power to make the engine run it like gets it going then stops does this sound like the right conclusion?
