The cb200 works with a spring operated clutch and some pins. This system is, after 37 years at it's end.
You can relatively easy (depends on your skills and tools) replace the worn parts. Thats the only way to do it.
Part numbers 11, 12, 22 will do the trick as far as i know. You'll need 3 of each.
Depending on what you're going to find in the engine you might need to order more parts.
http://www.cmsnl.com/honda-cb200b-usa_model1005/partslist/E++04.html#results
