AgentX
Over 1,000 Posts
Hi everyone--
Trying to re-wire my bike to my own design, but using a stock LH control switch with a lot of extra wiring in it. (Signals I'm not using, etc.)
Can't find a schematic of the switch so I need to test all the functions to determine what wire should go where. Can I hook a lead up to positive side power source (using what I THINK is the power input for the lights, since it's red and goes to both the function selection and dipper switch sides of the housing), connect my multimeter negative side to the ground side of the power source, and test for voltage at the ends of the various wires in the various switch positions?
If this sounds rational, can I use the 12v vehicle battery, or will I melt something without load in the system? Can I use a 9v just to make it less cumbersome?
Finally, my horn doesn't have an obvious ground wire. There's an input going to the button, and I get continuity through it when I press the button. Does that mean the switch housing itself is intended to be the ground? Or am I really missing something here? I thought I'd have to run a wire out from the switch and back to a solid ground point on the frame.
Thanks!
AX
Thanks!
AX
