Switch Testing/Grounding
AgentX
Over 1,000 Posts
Hi everyone--
Trying to re-wire my bike to my own design, but using a stock LH control switch with a lot of extra wiring in it. (Signals I'm not using, etc.)
Can't find a schematic of the switch so I need to test all the functions to determine what wire should go where. Can I hook a lead up to positive side power source (using what I THINK is the power input for the lights, since it's red and goes to both the function selection and dipper switch sides of the housing), connect my multimeter negative side to the ground side of the power source, and test for voltage at the ends of the various wires in the various switch positions?
If this sounds rational, can I use the 12v vehicle battery, or will I melt something without load in the system? Can I use a 9v just to make it less cumbersome?
Finally, my horn doesn't have an obvious ground wire. There's an input going to the button, and I get continuity through it when I press the button. Does that mean the switch housing itself is intended to be the ground? Or am I really missing something here? I thought I'd have to run a wire out from the switch and back to a solid ground point on the frame.
Thanks!
AX
You need to specify what type of bike you're working on. If you're working on a CB350, there are plenty of color wiring diagrams that include the switches.
As for continuity testing, I used 9v batteries all the time to test LED bulbs, or test to see if the circuit is working. No problem at all with that idea!
It's an Indian model royal enfield (as opposed to export) so I have no hope of finding a schematic here, alas. I have asked on some Indian boards, though.
Just want to know what I need to do if I have to figure it out myself. Thanks for the testing tip-will be much easier with a 9v!
Edit: Whaddaya know? I managed to test all the wires and chart out a picture of how the switch functions!
