Was that me? Seems I don't hold politicians in high regard.
On the cone question:
The larger the cone angle, the stronger the pulse is. Until it's too big and the waves are disrupted.
Think of a straight parallel wall pipe and the opening at the end as two extremes along the range of that variable. In a straight pipe, teh wave just travels along and no much happens to it. There's some friction along the walls but not much else. When a pulse (wave) hits the open end, there is a sudden expansion into what is basically infinite space. That cause the wave to be reflected back but as a negative pressure wave. A sudden opening like that works beast at only one RPM or multiples thereof. At all others, it's not so good.
Now think of a divergent nozzle (the first stages of your pipe) as a series of small stepped open ends. Now we have a long pulse being generated as the first wave travels down the pipe. Now add a second stage and what that does is to add a stronger reflected wave at a later time, so it arrives later. There's all sort of math involved but basically you now have two waves arriving at different times with different intensity.
So for example you might design the pipe so that the first stage helps evacuate the cylinder as the exhaust port starts to operate. You might want that second stage wave to arrive after blowdown to "suck" gas all the way from the crankcase through the transfer ports to aid scavenging.
At some point that new fresh mixture is flowing out of the transfers, around the combustion chamber and straight out the exhaust pipes, so we want to push some of it back in to sort of supercharge the cylinder. That's where the convergent nozzles aka baffle cones come in.
With a pipe closed at one end (opposite of the example above) a wave is reflected with the same sign. A positive wave will be reflected back as a positive wave and in an expansion chamber it's often called a stuffing wave. The idea is that when the exhaust pule gets all the way down to the baffle cones the effect is like the expansion part but in reverse. Think of it as a series of closed ends reflecting back a positive wave which will "push" mixture back into the cylinder.
The belly section is just there to adjust the length and therefore the time at which those pulses arrive and the angles change the magnitude of the waves within certain limits. For example subtle waves have less peak effect but tens also to have less adverse effects off peak so they are well suited to a mild tune street bike. Big fat pipes are great on bikes with a cylinder wall full of holes and big transfer ports and large crankcase volumes, but are less suitable on motors with few/small ports and small crankcase volume to draw from. That's why huge fat pipes work on modern motors but are not so good on our old clunkers. Back in the day crankcase volumes were small to create higher primary compression to push gas through the transfers, but that creates a really narrow powerband because the short push pulse from the bottom end had limited time to work and was strongest high revs.
That's somewhat oversimplified and you have to keep in mind that I'm no expert. There are people who really understand this stuff at both a theoretical and empirical level. I just do this for fun and try to keep learning.
One other thing I learned but tend to forget when I'm welding a pipe is that it's best to weld along the seam of each cone and then planish them or roll them to get the seam smooth and the cone circular. Next thing is to repeat that after welding each section to smooth out distortion and steps at each join. I'm not a great welder so when a weld is going well, I keep going and then see how badly it distorted after I finish the whole pipe - not ideal. Get the cones/steps/segments aligned and weld and smooth the step out before going to the next segment.
Remember that this information is worth every penny you pay for it....
