Texasstar
Can't is a four letter dirty word
Wow thank you! First we will be using your engine break in procedure. We used cheap weed eater oil and pump gas (which I did not verify) last time to seat the rings but I think that was a huge mistake because even the cheap weed eater oil I have seen for sale is synthetic I want to use the KLOTZ castor at 20:1 this time.
We will also have CHT, EGT, and O2 hooked up...THIS time. EGT is going to be 7” from the piston and the O2 on the top of the belly.
Ralf said to start at 20 degrees BTDC on timing but what I have seen on the dyno we can start as low as 17. However at 17 EGT went up 50 degrees and was doing exactly what you said...rev’s went up because the rich mixture was heating the chamber changing the speed of sound so I am thinking in honor of Teazer and his Yamaha we will start at 19 degree BTDC.
Thank you for the spreadsheets will definitely use them. Paris Hilton tuning and don’t blow your load like a teenage boy. Got it.
Back to the putting on the Fritz expansion chamber my friend Michael Moore said this “Allegedly Walter Kaaden at MZ remarked that you know the 2T exhaust is getting to be the right dimensions when it can't be put on the bike without dragging on the ground, burning the rider, or requiring some major component(s) be moved to prevent the first two items.”
Sent from my iPhone using TapatalkView attachment 224663
