THE RD FROM HELL
Re: Time to make the rd look like it runs haha
Yup, looks tough, like it wouldn't flinch from a Chuck Norris crotch kick.
Na im just out to cut up every tank i own
If you run out I'll send you a couple to grind on. I find letting you vent is beneficial to the surrounding population.
Impossible.
But close.
Has Chuck ever kicked you in the nuts?
Sent by my Magic Pixies high on crack and mescaline.
Im a bit jealous I don't have your skill set...
I wish I could build like that and not have to buy eBay parts etc...but Im already having a bitch enough time installing "store bought" Moto Carrera rearsets.
One day, I will be worthy of this forum...one day...maybe the next bike.
Smile for me....see dont that feel good, now go stair at your rear sets untill you figure them out. Just becouse i do things a certion way doesnt me you have to.
Awesomeness wrapped in Bacon.
The gas tank is sectioned and welded out i still have to put air to it and try to seal the leaks (there is gonna be a few im sure)
Next is the oil tank planning. im still not 100% on how im gonna run the line,vent, fill neck, sight glass and fasten it to the gas tank clean. but im not gonna let that stop progress i spent a little time on resizing the front axl. But all and all its moving right along.
The ta do list is still pretty big
Oil tank build
18 inch Front wheel lace
Buy tire
Rotor spacers
Oil pump rebuild and side cover swap
Possible yz swing arm swap
lil battery box & hide electronic's
Head light ears
steering dampener mount
Seat and tail build tail light snd tag mount
French in mini speedo in head light bucket
Converting carbs to run premix???????
Get car coils
Electronic ing and rev limiter
Body work and paint
Telling my self this is the bike
i should have built to begain with
Ya gotta want it
Sent from my PB99400 using a recorded womans tennis match turned up all the way & cheap 80's skin books to forfull a nights agenda
Sometime act first, plan later, gets the job done!
But .... why do you have 'converting the carbs to run pre-mix' on the to do list?
Crazy
Becouse im running after market keihin pwk's flat slides and there is no oil fitting for the line
Sent from my PB99400 using braille
The swinger off this hunk of shit og yz may find its way on the rd up side down
Sent from my PB99400 using Tapatalk 2
make a low spot in the floor of the oil tank and then drill through that and the fuel tank and insert a short length of tube and seal around it. That will be the oil feed. try to get it as flush as possible with the floor of the oil tank. Replace the tank section and fit a vented flush fit filler cap. No sight glass, low oil level light etc needed.
Drill and tap the carbs manifolds or reed boxes (your choice) for a small threaded barb or vacuum fitting for the oil feed from the pump.
Job done. Check oil by opening cap, every time you fill with gas and top up as required.
The small flush mount fill cap is provin to be tuff to fing any ideas snd thanks for the how to on the oil injection ill look in to it i thought it had to go into the carb
I've seen the chopper guys use small flushmount fuel caps. I'll find a pic when i get home and on the desktop.
And if you go with the yz swinger, I call dibs on your current swinger ;)
ill take a look at the ds7 engine i have.. pretty sure oil is injected into cases not carbs.. i know the 74/75 h2 had oil fittings into carbs-also into cases for main bearing lube..
