THE RD FROM HELL
Re: Time to make the rd look like it runs haha
The DS7/R5's had the injector ports located in the outside rear position of the cylinder head.
saved me a trip to the shed..thanks
Got these in a trade there the same as the ones on the bike if any body is intressed i may get rid if them
Sent from my PB99400 using Tapatalk 2
On a 400 the oil pipes go to a special drilling on the lower front part of the carb just before the reed boot. Piston port motors are drilled at the side of the boss where the intake manifold bolts on. That applies to DS7, R5 and TD3. The oil feed can also go into the float bowl as is done on some Kawasakis or into the reed cage.
Try to avoid having them discharge into still air for example above a dead zone or to teh sides where there's a ribber intake stuffer obscuring them..
thanks teazer ill get with you on tbe phone befor i.do anything i cant reverse
So i mentioned a junk yz a few post back well here is the skinny the chain was on the wrong side on that bike god only knows why that was a good idea. Im toying with losing the dirt bike mono crap and flipping the swing arm so the chain clearence stuff is on the side god wanted it and adding twin shock mounts i also need to take a little out of the now underslung brace i think i need to distroy one hand made alum swingarm to build another due to some one off parts ive already had made for the first rig so sorry redbird the old one is not on the market its under the knife but ill build ya one for some clubmans and dinner if your not in a hurry
This swing arm if i can pull another rabbit out of my hat will allow me to run a rear disc spoked wheel that i want to build
Ya gotta want it kids
The junk yz and the sheet of steel puts my remodel to a grand total of 37 bucks and three rare gas tanks that i distroyed
But dont worry guys im just getting warmed up i may break a. c-note haha i will end up dropping some money im just using shit that ive been gathering up for two years now several 13mm spacers and custom bla bla one off will start soon
You're a savage. This bike is going to be the real deal man.
I did some reading and some more reading on how to shorten front forks correctly and im almost there. i snapped a picture at quiten time last night. Also the swing arm build is still up in the air
Also The 19' front wheel is dead to me 18/18 is the combo im going with
Started on the tail section
Hows the fuel/oil tank going ?
Havent messed with it as of late but i decided to de muffel my little bike and while i was at it i i turned a cone or to and wala
