stroker crazy
crazy as a fox
Welcome to the crew!
Added your name to the Owner Locator.
Crazy
Crazy
stroker crazy said:Welcome aboard nicopotvin!
The hole needs to be blocked, as Caferace1968 says. Even some epoxy filler like JBWeld or similar should suffice.
Crazy
Shawn.male said:Im keen to deal with exhaust next. Wondering if anyone has one of the "factory" chrome non-cat exhausts fitted.
If so, does it yield any improvement in performance and sound?
2b said:I didn't bother, I ordered the OO Racing header and an Emgo muffler which I repacked with some fluffy two stroke packing. This gave me a great improvement in sound and better acceleration, no impact on top speed but much more satisfying to ride. Just had to rejet to match the better breathing.
Erskine said:You could fit some handle bar weights to extend the bars:
http://www.getgeared.co.uk/Motorcycle_Steering/Motorcycle_Handlebar_Bar_Ends
You can buy all kinds of grips .... just do a search.
What are the OO shocks like .... do they damp effectively?
With the tyre and rear shock upgrade, It may be worth changing the fork oil to a known quality, even upping either the volume slightly or going up a weight to improve from end damping. If you go to heavy the front end will be solid, but by mixing equal amounts of 10w and 15w will give you 12.5w ish etc you can experiment and find optimum damping for your weight and riding style.
sprocket2cog said:now have a 5.5inch headlight with an led globe …
i found the headlight on ebay, it was chrome side mount with a ba20d fitting , i cant find it now it was nearly 2 years ago i got it.stroker crazy said:I'm looking for something like that - where did you find it?
Crazy
sunbeam61 said:Rode for the 1st time in the dark. There are a lot of roos around Canberra and unlit streets ,so was rather disappointed with the factory headlight. I will get a 7inch to replace it . Can anyone confirm if the wiring can cope with a H4 halogen , or would I be better off getting a standard globe type?
thanks Chris.
[/pic]
