sprocket2cog
looking good.
stroker crazy said:Finally put the de-cluttered crankcase cover on yesterday:
Total weight saving over 2kg!
Yes, I did get carried away with the drill; speed holes make a bike go faster - right?
Crazy
mikeyw64 said:How did you remove the Skyteam name?
Remind me, have you removed the rear mudguard or not?
stroker crazy said:File, 120/240/320 grit, Scotchbrite+WD40.
Rear guard stays - I have an aversion to skunk-stripes!
Crazy
stroker crazy said:A hair-dryer on low heat softens the adhesive enough for them to be peeled off without leaving a residue of glue.
Crazy
stroker crazy said:The gearbox on my bike was quite my was quite 'notchy' until I got a few kilometers covered, but has improved considerably.
Something that may help in finding neutral is the following:
Come to a halt in first, holding the clutch in.
Change up to second, then give the gear lever gentle downward pressure.
Hold front brake while slowly releasing clutch.
I found the neutral indicator light to be unreliable so I have disconnected it. I don't like being lied to by machinery!
Crazy
ChrisBNE said:Had that happen over the first night that I had the bike. Was running on the day I finished the bike, next morning got up to take her for a run and it would't turn over. One of the kids had hit the kill switch!
a larger view:
Crazy
