The SkyTeam 'Ace' Resource
Anyone here from Brisbane?
Is anyone here in the Brisbane area?
Someone off a Bird forum is considering selling his ZZR1100 to fund an Ace :)
Ah just realised ChrisBNE is up there, will tell Ian to set an account up & get in touch
bubonicplay said:
Not sure where this is mentioned but what kind of shocks are you running?
I'm running these (also available in other colour ways)
http://www.ooracing.com/store/index.php?act=viewProd&productId=4630
Yep I am :)
ACEitup said:
CAT removed ;D
header pipe extended and megaphone fitted
bought a smile to my face immediately
with power increase but was surprised
top speed still 90 k's?
Will finish off pipe with a titanium wrap
also might have to tinker with baffle?
cheers ACEitup
On the flat/freeway I can do 100-105 and only stock intake/exhaust...
I'm same weight as you buddy and I'm a broad mofo. Don't get me wrong, as soon as a hill comes along all bets are off!
If it makes you feel better (or worse) I'm around 107kg fully suited & booted and can get a steady 63/64mph (approx 100kph) on the flat
Uphill, well you've seen my video on the Cat & Fiddle (few posts back, speeds shown in mph) which was an 800 ft (243m) climb over 6.3 miles (10.1km)
http://goo.gl/maps/jAuBF
EDIT:
Just checked and allowing for the time until I started moving & slowing to turn into the pub car park I did it in exactly the time Google says it takes :)
Hi guys,
Haven't been following the thread for a while, need to catch up on it.
Anyway my Ace has finally arrived!!! Stoked!!!
I like the black too. I'd love to pull the fenders off, shorten the front one and paint the tank/sides black.
Welcome to the club and enjoy!
sprocket2cog said:
you dont need the whole of the ooracing kit unless you want to get it all, you can make do just getting the jets , the blanking plate and a front sprocket with 17 teeth, then you dont need to shorten the chain, which you need to do if you change the rear to a smaller one.
I am ordering the stuff from OORacing you have recommended:
- Product Code: 7329 - EGR Cylinder head exhaust emission blanking plate
- Product Code: 8685 - Re jet kit for Skyteam ACE 125 using standard air box
But I am not sure which sprocket is the right one:
Product Code: 0957 - 14T 15T 16T 17T 18T 428P 17mm shaft Front Sprocket (17T)
or
Product Code: 0960 - 15T 16T 17T 428P 20mm shaft Front Sprocket (17T)?
Also I would like to put on new set of tires (it was quite wet when I took her for the first ride and had quite nasty rear wheel skid), but I would like something a little bit chunkier - do you guys think I can put front 3.00 and rear 3.50 on? Or it must be 2.75 front and 3.00 rear? Any suggestion which tires to choose? I would like something classic looking - TT100 pattern kinda style - I was thinking Dunlop K82, but not sure whether you can get these here in Oz/
Thanks for your help!
Thomas
or
Thomas
Does kit with all this in it include that detail? http://www.ooracing.com/store/index.php?act=viewProd&productId=4299
or
Thomas
looking at other listings on ooracing it seems that the 125 has a 20mm shaft for the sprocket.
http://www.ooracing.com/store/index.php?act=viewProd&productId=4639
dont know 100% maybe someone else here knows.
Anyone got any suggestions? as to
why I'm not achieving similar results?
I no its not the brakes ;D
I havn't rejetted yet and new muffler is reasonably quiet until you rev hard
emgo 24" megaphone
and engine does have a slight flat spot, more so when cold
Are you guys running those CDI things?
still have a standard sprocket and a capped off egr
only done EGR valve.
have you checked tire pressures? could make a difference, as at that velocity every little bit counts.
I haven't replaced the bolt I stripped last night, could be that weight reduction!!
