First off... WOW! steve this wire harness ROCKS man! just amazing work, clearly labled, well done, just a breeze to install...
got the whole bike wired up, just did not get the front switches done... fresh oil is in, new plugs all gapped up, new filter... baffles are mounted in the pipes and bolted in, new exhaust gaskets are in, pipes are on for good, oil lines are on for good, sprocket case is on and loc tited in, bar end mirrors are done and on, battery is on the charger... got to finish the switch wires tomorrow, toss in some gas.. tune in the points, fire it up, balance the carbs... and wait for the F'N SNOW to melt!!! to see whats up on the jets and to finish the paint... Steve... thanks man A+ work will deff use your work on all my builds here on out!
anyone looking for a custom wire harness, hit him up!!!
http://dotheton.com/index.php?action=profile;u=679
Fitting the brains
Pulling wire
Inside side case #1... you can see i was able to use the stock tool storage to house the brain box of the system
Inside side case 2
all the wires going up top have been wrapped in the chrome sleeving
Everything is all wrapped up and leading into the headlight
Tail lights are wired in... I will sillicone in all the wires so the zip ties will all be cut away... (off to the left is the wiring for the horn and button... still needs to be tied up)
