TX500 Newbie
Samurai_x
Hey everyone. I've been lurking for a while but today I finally got to ride my bike I got a few weeks ago. I took the class and got it registered yesterday. A 1974 TX500. After I got it I realized I had purchased yamahas bastard child but I want to make the best of it. Its my first bike and I took the safety course a couple weeks ago.
So its got a nice oil leak from the head, it tops out at 55mph and after it warms up at idle it will rev up to about 4500rpm and just sits there. And I also noticed it while shifting gears. It has some cone filters and was thinking maybe it was causing it to run different than a stock air box or the carbs will need cleaned?
Ill have some pics up asap.
This is it in the garage from the guy I got it from. I probably paid too much for it but you learn from your mistakes lol
ill get some more recent updated pics.
So any ideas on my problems? I checked the throttle cable and its not sticking.
I've heard these run like crap with stock carbs and pod filters. I just left the stock airbox on mine to avoid any of that. Are they the factory carbs?
Sent from my PC36100 using Tapatalk
Looks familiar :)
If you are ditching the factory seat and don't mind selling it, let me know. Girls seem to always want to ride on the cafe and not the streetbike, but I sacraficed my factory 2-up seat to make the cafe seat work. So if I had both I could just pop it on there when needed. I also have a decent amount of spares if you need anything.
Very nice! Is that original paint? or did you repaint it? and if so what paint and where did you get it from.
Atm I plan on keeping the seat and maybe later build a new modern looking 2 up seat, but I will def let you know and keep you posted on the status of that.
When I bought it the guy didnt have the stock air box and that was what was on it. Im checking around for maybe some air/vacuum leaks and someone suggested checking the mechanical timing advance weights to make sure they arent sticking.
Thanks! Mine started out just like yours minus that sweet desert paintjob on one of the sidecovers haha and the motor was locked up. The paint isn't original but it looks like a dead-nuts match. I believe my guy used Honda goldwing blue but I'm not 100% positive. It was a factory color of some modern bike though.
Ebay has been pretty good for getting parts for me. You just have to be patient its really hit or miss at times.
So did you rebuild the motor or just free it up? Mines got a bad leak and I'm thinking about swapping the 76+ motor since its not the 2 layer head BS. Or just swap the head, IDK yet.
Yea I ended up rebuilding the whole thing. I would recommend swapping the head if necessary. I haven't had any problems with it besides leaks, but I've seen the later heads and the design is much better.
these bikes run hot! that is why they are know to have cracked heads... check it before digging into it... tv321406
i have a stock seat from mine... (nice shape too)
i made a jack plate oil cooler for mine to keep it nice an cool... i am about 60% done with the carb conversion to VM30's
Looks like it is mainly coming from the front of the head between/around the 2 exhaust.
Any ideas where there could be possible vacuum leaks?
Also checked mechanical weights and spark plugs. Plugs are a little black but still seem to spark. Weights are freely moving and spring back. I put some seafoam in the gas tank sunday and have been tinkering with it every night after work and now its backfiring BAD! Im thinking I messed the timing up a little checking the weights.
On a good note I did get my gas cap overhaul kit in from UK and put it on with no leaks!
Good to see more 500s on here ! So how far are you planning to go on your bike? I believe you will be able to use parts off other yam 500s and a few RD parts.
Im wanting to get the motor mechanically sound either with a new head or 76+ motor. Its hard as hell to find a 76+ head. After I get it running nice and smooth Ill work on aesthetics. I want to make it more modern looking but keep the frame the way it is and keep the dual rear shocks. Drag handle bars, 2-1 exhaust Custom make new front and rear fender. New modern 2-up seat try building the tail light into it. TRY to make all the lights LED. And I really dig the 7 spoke wheels like on yours DreadRock. Maybe find some newer/nicer/better working carbs. It will be a slow process but we shall all see.
First things first, a 76+ motor or head that I can swap!
sounds like you have a good plan going . im sure there are a few 76 heads out there. the wheels are off a 77 RD400 along with the swingarm and rear brake. i didnt know at the time but a xs400s has the same wheels and bolt up much easier. any way keep to your plan and cant wait to see what you come up with......
if you have seeping though the exhaust area that is usually where the heads crack... clean it off with some non colorinated brake cleaner and look real close wiht a light to look for stress cracks in it
yep my carb boots where shoot on the out side but looked ok on the inside . but didnt want the stress of leaks so found a new pair. try speed@sport.com they seem to have alot for the yams ! as for the wheels wanted to go wire wheels like waht came on it but way pricey so i cheaped out and went with spoke and am very happy i did. JRK would be the man to ask about what would work for you more then me . im still a noob on what fits what but learning !
