Re: vintage race CB350 - exhaust
Long time no update. Finally got my 2-into-1 exhaust system mostly sorted out.
Merge collector
Received my custom fabricated 2-into-1 merge collector for 1.5" head pipes with a long transition to 2-1/8” outside diameter with a 6" long tail pipe. Made by Burns Stainless entirely of 304 stainless steel. Part number MC2-150-16-304.
2-into-1 exhaust
Everybody has their preferred exhaust setup. This 2-into-1 setup is a noise compliant system that offers plenty of ground clearance and lots room around the footpegs to operate the controls and kickstarter without interference.
I perhaps would have maybe preferred a more classic looking 2-into-2 system with open reverse cone megaphones like fitted to classic Grand Prix machines back in the 1960s. But the world has changed and race bikes now require mufflers, which more often than not means non-original exhaust systems must be used.
All design is a matter of compromise and this is the setup I ended up with given my requirements, budget, skills and time constraints. Next time I think I'll try making an exhaust system made of mild steel with custom baffles packed into the long cone megaphones with CNC machined billet aluminum end caps. But for now, onward and upward....
Side view exhaust pipe
Still need to weld spring hooks on so I can secure the head pipes to the collector and the collector to the rear slip-on muffler section.
I also need to take a picture with the bellypan installed.
Untitled
Footpeg clearance
Footpegs will drag before the exhaust does.
Top view
Muffler hanger will be getting a re-do. Aiming for a more upright mount attached to the frame seat loop made of laser cut steel that is bent into shape and welded. Finally gives me an opportunity to try out my new dimple dies.
Dimple dies
Dimple dies
Barnett Kevlar clutch plates
Received my Barnett Kevlar clutch plates and HD springs. Yes, I know you need 8 of these, not 7 as pictured. I wish I had spent the money and installed them back when I had the motor all torn down for a rebuild to avoid rework. C'est la vie.
I also modified my sprocket cover to retrofit a Suzuki worm gear type clutch lifter mechanism that also received a modified lever arm. A lot of people question the need for this mod but given the other changes I've made to the clutch operating mechanism I felt it was worthy. I got the idea from Jon Sunter who race prepares CB350s over in the UK. This solves the problem of my aftermarket Magura clutch lever over-travelling the stock Honda ball and ramp clutch lifter mechanism. Unfortunately, the hand lever effort remains rather high despite proper cable routing and lubrication so I'm going to fabricate a custom lever arm for the clutch lifter that increases the mechanical advantage while still giving me the necessary travel so I'm in the sweet spot where the clutch doesn't slip nor drags under varying load and temperature. I could have just as easily decided to get a different multi-adjustable clutch lever from MSR, AVS, CRG, etc. but I wanted to maintain the classic Magura look. This is a perfect example how how one modification can snowball and require 4 more modifications to get the system working ideally. The end result should be a clutch that is easy to operate and maintain and is reliable.
