WIRES! CB550 issues
Putting this harness back on the bike and having an issue getting spark. If its hooked up with out the killswitch, I can crank the motor over fine. Once I put the flip the switch to run, I blow a fuse. Could it be ground?
Sent from my iPad using Tapatalk HD
Here is a bit more information. I'll be posting this in a few locations so please forgive me if you read this more than once.
The engine will spin when pushing the started button. Pistons are moving just fine. The clutch has to be pulled in order for that to happen which, I thought was interesting as the bike was in neutral. My 400 didnt have that issue. If the bike was in neutral, you didnt have to pull the clutch, but I digress. So, that was very exciting.
Now, I dont have spark yet, however, I have the black from the starter button AND the kill switch attached to the same 4 way black connector (see picture, the yellow that is being plugged in is just a heat shrink as I ran out of black in that size). If the kill switch is not plugged in, the bike will turn over as described above. Once I plug the kill switch in , I get a few random sparks from the coil while Im not trying to start the bike and then the fuse for the red pops before I can get any further. I can still turn the bike over at this point, but of course, no spark. I feel like this has to be a grounding issue, but I think I checked my grounds pretty well.
I have continuity between all points for grn. there is good frame contact for my ground as well. I stripped the paint off well.
Anyone have any thoughts?
Fixed the spark issue. Shielded the coil wires and changed to a 7A fuse. Sparks like crazy now. Only have to figure out why Im not getting any fuel to the cylinders.
I've gotten pretty far with this bike as of late. Last night I had all the indicators working, the rear brake working, the speedo gauge functioning (albeit in km/h). Things are looking pretty decent.
I seem to either have a bad battery (again) or a charging issue. I gave the bike a full charge this weekend started with the starter rode it around the block for about 20 min pulled back in to the garage and went to start it with the starter and got nothing. Wouldnt even turn over once. It will kick, but I have clearance issues with the rearset (DOH!).
I have a 9 amp battery. I know it's on the small side. I was planning on using the kick.
How would I test the charging system?
To see if she gives enough juice, start er up and put an voltmeter on the battery terminals. You should get a 13.5v at 2000rpm, 14.5v at 6000rpm,
If it stays under the 13.5 consistently, your generator, regulator or rectifier is dead. Now, generators normally don't die, so my guess is on the regulator or rectifier. If it goes above 14.5 its the same.
You can check them, measure them and replace them, but i strongly advice you to buy a new combined unit for around $100. It will work better then the oem shit they put on 30some years ago. here's a link to the one i'm running:
http://shop.honda4.nl/catalog/product_info.php?cPath=901_148_220_547&products_id=1227
Good luck!
Hey Bert,
I have one of those units already. It could have some crappy wiring. I have to check that but I will rev it up tonight and see what the meter reads. Thanks for the tips!
I did a quick test when I got home. The battery was drained again but I was able to jump it and get it running. What I could tell was that when I rev'd up the motor the volts would climb. It was a little less than one for every thousand rmp's or so.
So does that rule out the stator from being bad?
Something I did think about is that I have the 3.0 ohm Dyna Coils. Could those be too hot for the 9amp battery?
Other than that or a bad battery what could it be?
Just got off the phone Dynatek. I was originally advised by them to purchase the 3 ohm coils but after a lot of reading and a scone phone call, I was told that 5 ohm is the recommended coil. Makes sense now but kind of irritated that I was told something different from the beginning.
Dynatek recommended an inline ballast resistor of 1 or 1.5 ohms. Seems to be the cheapest solution and the guy said there is no adverse effects on the system.
Working on the bike the other night (thought I had broken a ring but turns out I did not) and while I was putting the top end back on, my wrench hit the fuses, sparked and blew the fuse. I got everything buttoned back up last night, turned the key and I have no power anywhere. I tested all of the connections that should have power and I get nothing.
I remember that there was a way to test across the fuse box with a multimeter. Anyone know how?
Figured this out. Used the continuity tester to traced down a cooked red wire coming out of the block. Crimped new connectors and the problem was solved.
Nice! Congrats! Feels good to find the crulpit huh?
