sxecafe
You think the Carpet Pissers did this?
Hi,
I am wiring up my 550. I tested a bunch of things last night. Continuity for all wires is good. I have replaced the plugs with new units. Mine turned to powder when human skin came in to contact.
I have a this battery:
It's reading this:
I feel like that's low. I have tested fitted a few things but really, only LEDs. Shouldnt be drained that much. I have a trickly charger but wanted to be sure that the gel cell batts are cool to go on there before I start charging.
Also, this is the first vehicle I have ever wired. I have changed a few basic components before but nothing like this. I am using the stock wire harness, which was in great shape. I put new connector pins on it (like I mentioned) and the following have been replaced:
- New Reg/Rec unit (picture below)
- Two pin turn sig relay (picture below)
- Emgo Ignition Switch (picture below)
I tested the Alternator and everything comes in under manual specifications, so it looks like that's good. The battery, as seen above, looks low but even still, I cant get running lights, turn sigs, anything to read... Don't know where to go from here. Looks like all my components are good but I must be wiring something up wrong or out of sequence...
It's reading this:
