"Woods" - '73 CB350F
ahhh thanks. For some reason I always forget about ebay. Found a bunch of kits, unfortunately in Canada, but will order it up.
Thanks guys!
imseamless said:
I'm living in Seattle. How is yours coming along?
It's going slow, I got a new tank and seat coming in the mail as well as a complete gasket kit and oil seal kit but I am at a standstill till they get here. I want to have the bike done by April/May but it is probably going to be something like June.
JR
Re: "Woods" - '73 CB350F (Bought new stuff!!!)
So after a bit of convincing myself, I decided I'd take care of the head gasket while I had the bike tore down. The second local shop I called had a top end gasket set for my bike that the guy said had been there since he has worked there. Must have been saving it for me. With the intention of buying the $40 gasket set and leaving, I failed miserably. Walked back to my truck with the gaskets, a new battery, new headlight mounts and some old battery cables because mine are too short. 100-some-odd-dollars-later, I made it home. So this weekend will be the big engine tear down. I have heard both sides now: You can replace the head gasket with the motor in the frame and also you can not. Well, I will tell you this weekend if you can or can't because I'm doing it either way.
Since I bought a new battery, Ill have to scrap the battery box I welded last weekend and make a new one. Thats ok though, more practice welding won't hurt. Going to order some gators for the forks so I can get those ugly aluminum covers off the forks and probably buy some clip ons a bit later down the road. At least I'll be prepped for them. Commence photos!
Nice bike, Ben! Good work so far - I'm excited to see how it comes together. I've got a 350F as well.
About your fuel issue:
You might want to install a clear inline fuel filter; it's an (unnecessary) safety net to protect your carbs but - more importantly for your needs - you can see if gas is in it when riding....this would let you rule out the tank/petcock by looking at it whenever you're having issues.
Good luck!
On swapping the head gasket, well you may be able to do it in the frame, but why would you? It would be WAY easier to just pull the motor, it is not that hard, I pulled mine (350f) by myself last weekend!
To be honest, I'm a bit intimidated. This is the first bike I've really tore into and I'm a little hesitant to disconnect everything and pull it out. I know I probably shouldn't be. Just gotta make sure I take my time and keep everything organized. Can you offer any tips that may help an inexperienced guy out when it comes to pulling the engine?
Ben
Ben, if you are willing to go into the motor, then a think you have a set big enough to remove the engine from the frame. I have done a lot of work on bikes but I have never done a full rebuild of an engine, this 350f I am building now will be my first time to go all the way through an engine. I have however pulled several engines and replaced them. I have enlisted some help from DTT guys to go through the engine on Caroline with me, just to teach me the things I may not know, like little tips and tricks of assembling an engine properly lubed and all. Anyway, I suggest you pull the motor! First drain all the engine oil and remove the oil filter cover and oil filter. Remove the primary drive cover and the charging system cover with the magneto in it, just to protect them. Once you have all that out, there are just a few engine mounting bolts to remove and you can slide the engine out on the right side of the frame (brake side). Tip: Remove the front engine bracket completely from the down tube before removing other mounting bolts.
That sounds simple enough. I've read about people laying the bike down and lifthing the engine out, but it sounds like you recommend keeping the bike upright and sliding it out the brake side? Did you use some sort of make-shift dolly or ...?
I had the bike standing and straped into my lift table, so the frame would not rock or move while I monkeyed with the engine.
i pulled mine with it braced by a friend and on its centerstand (like tWisted said); it's the recommended method in Clymer and Honda as well. It's easier with a friend - that sucker is a little heavy and awkward! Also, removing the breather cover and/or oil pan makes it easier as well, you just have to be extra careful with the bottom if remove the oil pan.
+1 on removing the front engine bracket from the downtube. Wish I had done that the first time.
Don't be afraid of that engine, brother! Just be organized when you remove it (bag and tag bolts, nuts, etc.). Don't forget to check the torque on your head nuts...can't remember off the top of my head, but there is a specified torque and removal/installation pattern. Check your Clymer.
I'm just playing devil's advocate here so don't put too much thought into this if you don't want too...
Is you're compression good?
You don't have to answer that....I'm guilty of domino effect thinking - i.e.: if you're gonna replace the head gasket, why not replace the lower cylinder gasket; if you're gonna be in the engine, why not hone and re-ring; if the engine's out, why not tear the frame down and powdercoat....as least that's how the scope (and timeline) of my project has grown!!
Im definitely feeling this!
I know i know. Doing one thing leads to doing five others. I only bought the top end gasket set so i'll probably just be doing those. i would like to hone though.. agh
It looks to me like you have all of the gaskets you need if you want to hone and re-ring, but if compression is good then you really don't need to.
Today was great. For the past week or so, all my work has been part of a bigger piece and today a ton of it came together. First off, I showed up and my dad had made me a box to hold my battery. I was really excited and it looked/worked great. I definitely appreciate all the help I can get and it was really cool he took it upon himself to do that. So I mounted the box to the bike and welded in the replacements for that plastic mud guard. Next I cut some steel for act as seat mounts. Figured out how to mount the seat and the brackets and welded them in place. Grinded some channels in the steel for wire management and wired up the battery. Cut a hole in the seat for the brake light. Sanded down the seat and laid a few coats of primer and the first coat of flat black. Finally, I made a license plate mount out of some steel strap.
Today was great. What made it even greater is that while typing this, I got a phone call saying my jets finally arrived! I'll put those in tomorrow or Monday.
Here are some photos from the day and an updated todo list.
and wait for it........
Updated Punchlist:
-install larger jets
-Put pod airfilters on carbs and hope they fit
-cut metal to hold battery (In Progress)
-weld on battery holder and mud guard metal (In Progress)
-spray those pieces
-Mount battery (zip ties or straps?)(In Progress)
-mount seat (aluminum bracing under seat?)
-cut hole in seat and mount tail light
-paint seat (In Progress)
-find some padding for seat
-mount license plate (bracket to mount under seat on steel piece)
-sand down gas tank and clear coat (In Progress)
-pull off clubmans
-buy clip ons and new headlight brackets (In Progress)
-possibly replace stock switches on bars. No signals/elec. start so only need a kill switch
-Put gaters on forks/lose aluminum things (In mail from DCC)
-new footpegs (not sure I want rearsets at this time)
-continue going through wiring harness and cleaning connections
-replace head gasket
-BE DONE BY MARCH 16TH, 2011
Re: "Woods" - '73 CB350F (IT LIVES!!!!!!!!!)
I type this from my parent's garage, the place I've been building my bike since I live in a small apartment in the city with no where to build. I type this because today is a very exciting day. I appreciate all the help I have received from this website and the people that offered that help. With that said, this morning I rejetted my carbs to 85's and put on pod filters. I rebuilt everything and it started up second kick and runs stronger than ever. It climbs through the RPMs without missing or lagging. It also has a lot more balls! I honestly can't believe how well it has come together, but I am ecstatic I was able to accomplish this mostly on my own, but it wouldn't have been possible without the help from you guys and my dad.
I took a video of the bike running and uploaded it. Unfortunately, it says it "won't be ready to view for 1 hour." I will post the video as soon as it works!
You guys rock! The bike is 80-90% done at this point, just small stuff from here on out. Next weekend the head gasket goes in!
Re: "Woods" - '73 CB350F (VIDEO)
Just rode back to my apartment (28 miles) and she ran great. I started backfiring as I was coming off the freeway so I parked it and let it sit. Could this mean its running rich?
And here is the video
Untitled from Ben Woodward on Vimeo.</p>
Re: "Woods" - '73 CB350F (New Photo)
After all the work I've put into that bike, I feel so nervous parking it on the street.....Notice the U-Lock through the rear tire.
