"Woods" - '73 CB350F
I'd be willing to bet it's the petcock. I had the same problem on my bike last year. Next time you go for a ride take a piece of 1/4 tubing and needlenose pliers with you. When it craps out, hop off and use the needlenose to pull each fuel line individually. I'll bet my left nut you won't have gas flowing out of one of the lines. Thats where the fuel line in your pocket comes in. Stick it onto the petcock on the side that fuel had stopped coming from and blow into it. It will start to flow immediately. Re-connect fuel lines and be on your way. It will crap out again as soon as you use the small amount of gas that was able to make it into your carbs. I'm sure it can be one of two things- bad petcock or bad vacuum.If you replace the petcock go with a Pingel.
Reinhard, thanks for the info. I'm a little unclear though, so you're saying pull the fuel lines at which point? I have a main line running off the petcock to a nipple, which, i believe, then distributes fuel to the 4 carbs. So when the bike stalls, should I pull the line off the petcock and blow into the carbs, or pull it off the carbs and blow into the gas tank? Or do I do that with the piece from my pocket?
Sorry for the trouble, I just want to be sure I can follow your steps accurately.
Thanks,
Ben
make sure the gas tank is vented. I had the same problem on my 350F and turns out when the tank was kreamed, I sealed the vent in the gas cap. It would create a suction and starve the carbs of gas after a few minutes of riding. I figured it our because I would stop, open the gas tank to do a visual on the level of gas, and it would start right back up as if nothing was wrong. Removed the kream over the cap and I've never had a fuel problem since.
It sounds like a similar situation. Good Luck!
He has tested the venting, and on a CB350f, the petcock only has one outlet, that serves all four carbs at a spliter right above the rack of carbs. First try the reserve, you may have a bad petcock, or you may just be low on fuel!!!!!! If it runs on reserve, go fill it up and try the on setting again, if it still runs, you were just too low on fuel! If not, then rebuild or replace your petcock.
Nice build you got going on here. I agree with everyone else that its definitely a fuel issue. Good luck getting it fixed.
Pull the fuel line off the petcock, attach piece of tubing to the petcock outlet and blow up into the petcock. You'll hear the gas in the tank bubble and should start to flow immediately.
Re: "Woods" - '73 CB350F (TEARING IN!)
So I went to the gas station and filled up my tank. Bike still took a crap. Ran on reserve, same. Noticed carb 3 was overflowing and decided I'd had enough! Now we're getting into a big arse project! To be honest, I'm a bit releaved and excited. I should be able to remove the guess work by digging in. Lets get started.
Pulled the seat, tank, battery, fender, air box, and carbs. Pulled off all the float bowls and found bowl 3 caked with sludge at the bottom by the drain screw. That sure explains a lot. Cleaned all carbs and blew air through them. I decided rather than throw it back together, I might as well build it out since I'm this far. So that means jets and pod filters. From reading it a appears an 85 should do it. Do I just need to replace the main jet? Can anyone recommend a good source to buy from?
As I'm on hold to buy/receive jets and pods, I plan my battery and electrical relocation. I will build a small pan to hold the electronics directly under the seat. I have dimentions and will fab something this week/weekend. Looking at sealed batteries currently, probably a 12V 12A I suppose? Any Suggestions? I read a ton of other threads to no real answer.
Next I started flat blacking parts of the frame that will now be exposed to to battery relocation. Overall, I am so excited to finally dive in like this. Should be a very fun week and weekend.
Here are some pictures from today:
Mock up with new seat,
Carb bank,
Barnicals in my carbs?
Crap from float bowls,
and some paint,
More CB350F's on this thread than anywhere else so I might as well jump in :)
I hope you are going the right direction with it being fuel related problem. Sure sounds like it... but a poor electrical connection could be intermitant and temporarily "remake" when the bike is jounced.
I was also thinking along the lines of BCBarker and going to suggest you ride with the cap popped loose but Twisted says you already checked the venting.
'Tis a tough one for sure. The crap in the float bowls didn't help and you may have found it. A sticky float / needle could have been the issue all along.
Thanks for the photos and help Korndog12. That 4-1 looks awesome!
Hoosier Daddy, I did ride with the cap loose and had high hopes, but that didn't help any either. Sure hoping it is carb related at this point
Even if it is not the carbs causing the whole issue, from the looks of those, it was causing some effect. A good cleaning on those will surely not hurt!
Well, not at the moment, I am just not to that point yet! I will be jetting for pods, ported and polished head, and 4 into 1 open megga exhaust! Mrs. Cleo predicts fun in my future!
Re: "Woods" - '73 CB350F (Lots of photos!)
Got a lot of work done yesterday. The previous week I had drawn up plans to make a box for my electrical goodies to live in that would fit under the seat but was shallow enough as to keep the triangle of the frame clear. Looks like storing my bike at my parent's house isn't so bad (minus the 40 minute drive) because my dad surprised me by building the box, as he found my sketch in the garage! Awesome! He procured a small street sign and used tin snips, rivets and some flat black paint. I used a sawzall to take off a bracket that was in the way and cut some rubber for the bottom of the box.
Here it is,
Once that was finished, I started cut a few inches off the rear of the frame (my seat is super short), cut off all the seat and side badge brackets and grinded them down.
I sanded down the tins on the forks and put some bondo on a small dent. Then I put the tank and seat on and gazed at the ol girl for a while,
As of now, I think I want to sand the tank all the way down and go with the "raw" look. Is it as simple as sanding it down and clear coating it? Can anyone speak from experience?
Thanks,
Ben
ben,
as far as your running problem goes, as has been stated it sounds fuel related, but if I were you I would take the entire harness apart and inspect and clean every connection. Sounds like a lot of work but it will only take an hour or two and you will then know you have good connections through out the system.
And, yes. You can clear a bare tank. Just be sure its clean, clean, clean.
Diesel, I have been cleaning the connections as I come to them. I've only made it through the regulator/rectifier/etc area, coils and the headlight bucket. But I see your point and will be sure to make it through the rest. I've found one connection so far that seemed it could be temperamental; lots of play between the two.
Thanks!
I don't think those pods will fit that frame. The only ones I've been able to use on the smaller bore bikes are the foam Unifilters
