Roustabout
She's no longer just garage decoration ;D I caved in and mounted the 38mm TM flat slides because I didn't want to mess around with the stock pieces of crap. They were intended for the 750 motor I'm building and are a bit too much carb for the tame motor. I leaned out the pilot and main jet and verified the float level with a sight tube I cobbled together that screws into the float bowl drain cap. Re-tightened the exhaust, gooped up the carb boot gaskets, lubed & shortened the tired looking springs on the mechanical advance, made a throttle cable and mounted some pod filters. She fired up but was running pretty rich at low rpm so I adjusted the air screws bit before taking her up the street. She behaved pretty well so I put on the helmet and went for a run out in country to put her through some testing.
The transmission was nice and smooth, engine strong but the front brake was a bit wooden(though I have become accustomed to modern brakes). I hit a nice stretch of black-top and got her up to probably 90mph (5th gear 7k rpm) but I believe the spedo does not have the correct ratio as it was reading well over 100mph. The clutch will need a bit of adjustment and I will get some stiffer springs. I am also going to switch the carbs to a set of 36mm Vms as they are a period correct and probably a little better suited to a mild motor. The pipes made her sing like hell on wheels above 5k rpm and every animal I passed became extremely agitated
. The neighborhood dudes are all gearheads of sorts so I don't have to worry about pissing them off - they all love the racket that comes out her.
There is quite a bit of vibration transferred through the rearsets and clip-ons. I may have to go with rubber covered foot pegs and maybe some thicker grips or bar weights. If I absolutely can't stand the front brake i will install a 4piston caliper I have kicking around.
Monday will be the day of reckoning when I take it for a safety. After I have the safety my insurance company will set me up.
Port Dover or bust
Port Dover or bust
