XS850 - Monoshock & USD Fork (pics pg 13)
MotorbikeBruno said:
Yep lots of great info and re-checking there.
As for the pinholes. You are looking for any holes in the diaphragms. Pin holes can cause problems, but usually you'll find a rip/tear versus a pinhole. Best way is to hold it up to a light and slowly tug on the rubber giving it a slight stretch SLIGHT. So rotate and look for any spots light comes through is really all you are doing. The light behind just makes it easy if there is a pinhole due to their small size of course.
Right... I definitely would know if there was a rip in it. I'll take a peak for pin-holes tonight when I take them apart again, in preparation for the ultrasonic dip.
bruno hit it on the head. let us know how it goes! after ultrasonic - If they don't have pinholes or tears in the diaphragms, and no air leaks at the isolators....sync 'em and see where you're at. don't be afraid to play with float height like I said....1-2mm difference carb to carb is nothing to lose sleep over. It's also worth noting that each of your three cylinders might have marginally different lengths of exhaust, with no scavenging benefits from the neighboring cylinder....so that makes each cylinder even MORE independent in the tuning of the bike. If there's no air leaks I wouldn't worry too much about having different mixture screw or float height settings.
Double checked and sure enough, the pilot and main jet are both stock numbers. Of course that doesn't account for any wonky drilling that could have been done. It's that one really rich cylinder that is still mind boggling. Looking forward to the post ultrasonic results.
Thinking I'll try to fun them "as-is" after the ultrasonic cleaning. Then if I'm still seeing the same results I'll start attacking other things. Like A) replacing the jets with stock jets, and B) checking fuel height... etc etc et
C: New carbs :(
Welp... got the carbs back from their ultrasonic bath yesterday. Put them back together last night. Air screws all matched to see if my issues would be resolved. Not a damn difference. Still pop pop pop on the right hand side. Going to check the plugs tonight, but I think I know what I'll see.
Next step - buy STOCK jets and throw them in. There is always a chance these jets were tampered with at some point in time. If that fails, new carbs :(
Bummer dude. Sorry it didn't work out as planned :(
This is why we do this right? To solve problems? haha
It HAS to be jet related. I can't imagine anything else causing these issues. Fingers crossed... again.
is the popping coming thru exhaust ? if so are the exhausts sealed good, no leeks ? popping thru exhaust is a lean condition of course pretty common on some bikes at decel while riding the too lean mixture is sent unburnt into the pipe only to be popped off later by another charge and exasperated by the fresh air coming in at leekage or even the fresh air entering an open unbalfed pipe.are your pipes open ?
Ya, popping from the right hand exhaust. Definitely acting lean - as that's the plug that is traditionally white. So I guess the whole jets being drilled out theory might not hold weight. If that was the case I'd be rich across the board. At least switching that pilot jet from the 1 rich carb to the others would have made a difference. Shit!
It pops on decel, but when execration there is a certain throttle range where it almost acts like the right side isn't firing at all. Not sure if that makes sense, but that's what it feels like. Give it more throttle and it takes off and sounds great.
Exhaust crush gaskets are brand new, so I shouldn't have a leak there. Is that where you're talking about? it's possible that one of my muffler clamps isn't a perfect seal, but that wouldn't make a difference considering the mufflers are virtually straight through, right?
xb33bsa said:
what ya got glass packs for mufflers ? you cant run straight open megas on the street dude
They're not straight open. These are what I have: http://www.dimecitycycles.com/satin-black-17-inch-shorty-reverse-cone-megaphone-muffler.html
I just meant you can see straight through them (through a screen of course). They obviously do SOMETHING but I doubt they are adding much back pressure.
focusinprogress said:
have we sprayed with something to check for leaks yet?
Been meaning to do that... I will.
I've dealt with so many carbs over the last 4 years, but never anything like this. Baffled to say the least.
you should have done this long ago and repeat the check ever time you re mount the carbs godammit >:( :D
it is possible the throttle shafts are leeking as well and this type of check can uncover it,time waster :)
