XS850 - Monoshock & USD Fork (pics pg 13)
I suspect it's the float mechanism in the right carb. It's sliding, hanging up or the pin is binding. I would disassemble the right hand carb and check everything from the buoyancy to the pivot pin.
My XS650 right carb hanger was contacting the overflow tube and hanging up.
These carbs don't have an overflow, which means if the float gets hung out, fuel just starts pouring out of the air filter. I'm not sure how it could get hung up in a fashion that would make it close too soon, causing a low fuel symptom?
Trust me, it's a fuel flow issue. Try turning off the fuel tap and remove the drain just after running, you will find that that fuel bowl has less fuel than the others.
Trust me, it's a fuel flow issue. Try turning off the rap and removing the drain just after running, you will find that that fuel bowl has less fuel than the others.
Turning off the rap? Not sure what that means.
The fuel would drain out of the plugs inconsistently because the first drain plug that I pull will dump the gas in that float bowl along with everything in the fuel line on that side. Then the next one will only dump what was in the float bowl since the fuel line is empty at that point.
I meant turn of the "fuel tap" while its running to eliminate the fuel in the lines. You basically want to compare the fuel bowl levels. Easier on a twin that has two lines and two carbs :)
It can get stuck in the up position or bind on the side. Then you hit a bump and it drops.
Yeah... I hear what you're saying. Definitely more challenging with 3 carbs and 2 inlets. I'd have to try to burn off enough gas until the hoses are empty and check. Interesting point. Not against checking it out.
Super common in old carbs with old parts. My float needles are band new and definitely not sticking closed. Float hinges feel good, but you never know. It COULD be sticking closed, or dropping slowing after the gas is used, giving it a lower fuel level when the engine is running.
As if this wasn't confusing enough...
Yesterday was the first day I rode it with the needles bumped up another notch. It ran pretty well on the way to work with a little popping on the right still. So I pulled the air screws out a half turn before heading home and it ran REALLY well. Maybe one or two pops? But the hesitation/missing problem is completely gone.
Checked the plugs last night for the hell of it, and you're not going to believe this. 1 and 2 looked really good, maybe a TINY bit rich... but #3 was black!
Regardless... I feel like at this point I could get it close enough via air screw adjustments to stop messing with it. Otherwise, those xs1100 carb rebuilt kits and double checking the fuel levels is probably in my future. In the mean time, I'm just going to ride the hell out of it.
Find a way to lash up three KeiHins off an old KZ10000 and be happy as a short guy in the girls locker room.
Probably finally blew the crap out of it after the ultrasonic cleaning. You went for a ride and sucked it through or what have you, but it sounds like your mixture setting can work finally!
focusinprogress said:
any progress? :)
Been riding it too and from work everyday, trying to adjust the air screws for around town and I just can't quite get it right. Once the engine is warm it runs pretty well, but my drive to work is too short for it to really even get warm. I haven't had a chance to get our for a real ride yet, but hopefully will tomorrow! Higher RPM's and warm it sure feels good, just putting around town it kinda sucks.
I went ahead and ordered the XS1100 carb kits. I'm anxious to get those installed and see how it does. I still have a feeling that someone tampered with the guts in these 750 carbs, but I won't know for sure until I replace everything. Regardless, I feel pretty good about riding it. I need to go take some nice "complete" pictures with a decent camera to post up here. Just gotta clean her up and get out and do it!
So what is in the 1100 carb kits that is different than what you have now? I say this a lot (probably in this very thread!): Carb kits seem to all need the same modification. Open the box. Take all the brass parts out of the kit except the needle and seat. Throw all those brass parts in the trash and never look back. You now have a usable carb kit!
I had a guy call me a while back. Seemed very knowledgeable, but just couldn't get his bike to run properly (turns out not "properly" enough to be driveable). He had cleaned and rebuilt the carbs, complete tune up, new coils etc - everything. After a long conversation, I told him to try putting all the original carb parts back in and call me back with the results. Well he did call me back a couple of weeks ago and asked if I would consider fixing it as he had just worn himself out on it. I said ok, I'd give it a shot and went and picked it up. Checked the ignition and it looked great. Took one of the carbs apart and it was immaculately clean and perfectly adjusted. But it had all new shiny brass needles and jets with no factory Mikuni badges stamped into them. I've been down this road before, and didn't waste any time. I looked up the factory part numbers, got original OEM factory Mikuni parts and swapped out all the new "rebuild kit" parts. THAT IS ALL I DID! (Of course had to sync and adjust after the disassembly, and of course checked for clean, but the problem was unquestionably the aftermarket jets and needles!). The bike now runs FLAWLESSLY! Wish I could brag it was my other-worldly genius psychic engine whispering, but no - just put back the factory parts!
I know you have been through the wringer on this project already - this topic especially. Apologies for not reviewing the entire thread to glean if you have already installed all known factory stamped Mikuni parts - but if you have not . . . .
To sum it up... The carbs I have are from a 1979 XS750, not an 850. They were on the bike when I got it. After LOTS of reading on the Yamaha triples forum, I discovered that most who swap the Mikuni carbs from the 750 onto the 850 replace the guts with a set from a XS1100 which runs the exact same carbs as the 750 (Mikuni MKII) except jetted for the larger cylinder size (the xs1100 and xs850 have the same size cylinder). I would have gone with OEM Mikuni guts from an 1100 if I could have found them, but I couldn't. So I ordered a complete kit which comes with needles, needle jets, main jets, and pilot jets. If I have issues still, I guess I could blame it on the fact that they aren't OEM Mikuni parts, but what I am REALLY after is seeing if SOMETHING changes. Anything at all. If I could at least get all 3 cylinders to start acting the same I would be happy. As it is I am just not getting consistency which is driving me crazy.
Interesting input though on aftermarket vs. OEM. I'm sure with more digging I could come up with OEM if these aftermarket kits fail me.
Yep ;D I'm no Von Dutch of carbs but my exp with "kits" is that if you look close you will see the brass has whatever holes come close, look real close and most have burrs, over deburred edges, balls of millings inside... all kinds of machining errors. best to find a good set of unmolested carbs or find some of those now rare "old" yellow boxes with gold in em.
Not to say what you ordered wont improve the performance... If you need some brass though, I may be able to help.
Yeah, I hear ya guys. I'll give them a shot and see what happens. It was only $50 for all 4 kits. A rack of 1100 carbs on eBay are $300. If these fail and I have to piece it together with genuine parts I can do that. It's the emulsion tube/needle jet that will be the hardest to come by it sounds like. The jets and needles I'm sure I can source from a number of places.
Right, so if I understand rightly, you will end up with the exact situation as in my recent story - perfect carbs with brand new aftermarket jets and needles. Seems like at this point you have determined the carbs to be clean so you are only left with the uncertainty of the jets/needles. I hate to condemn all carb rebuild kits, and I am sure there are perfectly fine parts out there. But I have had this happen numerous times which is why I didn't even consider using the aftermarket jets - not for a second - this latest experience is only 2 weeks old!
Just hate to see anyone frustrating over things like this. I hope the new kits resolve all your issues, but If they do not, I hope you will consider biting the bullet and researching the oem parts and getting them. I know they can be outrageously expensive compared to the aftermarket parts, but there is a reason for that. In any event, having known components in your carbs is absolutely essential if you have ambition to get it correctly tuned. Jetting an altered engine with aftermarket jets (of unknown pedigree) is a complete and utter waste of time in my experience. I'll keep my fingers crossed for you though!
I've wasted this much time... what's a couple more hours ;) haha
I'll do some digging on those OEM parts so I at least have them tracked down as a backup plan.
Just putting this here so that I can find it again. Looks like this guy on eBay is parting out the rack of carbs I need...
Emulsion tube: http://www.ebay.com/itm/78-79-XS1100-XS-1100-CARB-CARBURETOR-JET-HOLDER-NOZZLE-EMULSION-TUBE-266-Y-2-/291543196883?hash=item43e15424d3&vxp=mtr
Main Jet: http://www.yamahapartshouse.com/oemparts/p/yamaha/620-1423a-78-a0/-jet-main-137-5
Pilot Jet: http://www.ebay.com/itm/YAMAHA-XS750-XS-750-XS1100-1100-XS400-400-XS650-650-MIKUNI-CARBURETOR-JET-42-5-/291522207097?hash=item43e013dd79&vxp=mtr
Needle: http://www.ebay.com/itm/78-79-YAMAHA-XS1100-XS-1100-MIKUNI-CARB-CARBURETOR-JET-NEEDLE-5GZ6-/301717104295?hash=item463fbda6a7&vxp=mtr
Source for parts numbers: http://www.yamahapartshouse.com/oemparts/a/yam/50041cd6f8700209bc78622d/carburetor
