Author Topic: My Suzi T500 Project *It's Alive Video*  (Read 264618 times)
Offline 50gary
  • Under the Limelight
Re: My Suzi T500 Project *New Video*
« Reply #1320 on: Sep 11, 2018, 20:57:24 »
NO!  ha, I'm a dyed in the wool roadie.  When I see a gravel road I make a turn.   I'm not against them it's just that I don't need another expensive bike.
  Cheers, 50gary
Short track speedskating, cycling, guitars, motorcycles, juggling dynamite. I was born to laugh at Tornadoes.
Offline johnu
« Reply #1321 on: Sep 12, 2018, 00:02:30 »
  Cheers, 50gary
You seem to have a better resolve than me, I can't help myself I want to do everything!  I'm in training for a 24hr time trial right now so full on road biking:)
Offline clem
  • static fluff
« Reply #1322 on: Sep 14, 2018, 09:52:03 »
I know I know it's been a long time since I posted anything.  Been having too much fun on mountain bikes and my KTM 500 ;D  Anyway I got a new twin spigot petcock and made an adapter to get it to fit my tank, also installed the new coil I bought.
Fired it up this morning and it started right away using the the chokes warmed it up then flipped the chokes off and it idles, give it throttle and it just cuts out... blocked pilots I shoud imagine.  I left the bike sitting with gas in the carbs >:(
Hey John, if the pilots were blocked it would not start or idle. Probably mains or maybe float height.
"After every war there are soldiers who refuse to surrender. To this day there are still thousands who cling to their 30+ year old motorcycles, thinking that the war is still on, refusing to concede that the four-strokes have won"
1972 DS7 http://www.dotheton.com/forum/index.php?topic=45886.msg505995#msg505995
1983 CB550sc bobber http://www.dotheton.com/forum/index.php?topic=30599.30
Offline farmer92
« Reply #1323 on: Sep 14, 2018, 15:49:09 »
If it cuts out immediately then it does sound like itís kinda lean there. What size were the pilots again? I have 45ís in mine with vm36ís.
What about the cut away?
Offline johnu
« Reply #1324 on: Sep 27, 2018, 17:18:22 »
Finally I've got the bike running half decent :) :) :) :) :) :) :) :)  I rode it further than ever before with no signs of it cutting out or running on one cylinder.  The jetting is still off but at least it keeps going now.  I'm going to mix up some more gas tomorrow and try to get a few miles on it as it is then see where things are it.  At least it is rideable now.  It still doesn't have much down low but that could partly be the tune of the engine and the pipes.
I did break the golden rule of changing two things at one :-\ I have new coils and the new dual outlet gas tap so not really sure what the breakthough is down to.
Incidently if you recall my last post where the bike wouldn't run without the choke on (it had the new coils and gas tap at that time) it was blocked pilots!
Here is a very short video my son took of me leaving the house.  We are going to try to get something better tomorrow.
I am so happy right now, it has taken a long time to get to this point partly because I lost enthusiasm for a long period.  :) :) :) :) :) :) :)
Offline teazer
« Reply #1325 on: Sep 27, 2018, 17:34:51 »
Progress.  That bike still looks totally amazing.  I need to go back to the early build thread to check out how you made the tank and seat.
BTW, was that first gear?  Sounds too tall.  Almost like starting off in second. Maybe take a tooth off the front sprocket and let the front wheel fly......
It also sounds rich or at least oily and stumbling a bit. Try to get the idle cleaner first and then work on transitions. Could be too much fuel in the bottom end after the last attempts and time sitting around.  Fresh gas is always a good idea.
Offline johnu
« Reply #1326 on: Sep 27, 2018, 17:54:25 »
You are quite correct, first time I ever rode the bike I realised that I got the gearing wrong!  I won't be changing the counter sprocket in a hurry as I made that up special to get the right offset for the chain run, it was a major project!!  I will have to change the rear.
Also yes it is oily/rich on the bottom, I'm going to ride it a bit first as is then start tweaking ;D  At least I have a starting point now that is much closer than it was :)
Offline teazer
« Reply #1327 on: Sep 27, 2018, 19:43:07 »
Gotcha.  Weld on a few more teeth at the rear (so to speak).
Offline johnu
Re: My Suzi T500 Project *It's Alive Video*
« Reply #1328 on: Sep 28, 2018, 18:45:38 »
Another quick spin today :) Think I'm going to go down on the pilots, it's still way rich on the bottom.  You will probably be able to tell what I'm talking about when you see this video.  I was trying not to rev it too hard being that it's more or less all new motor internals ::)
Things I've discovered now I can actually ride the bike: Suspension is way too stiff, handlebars are too far forward and I need to raise the seat up with a thicker pad.  And the gearing of course as Teazer mentioned!
I am over the moon though now that I can actually ride it :) :) :) :)
« Last Edit: Sep 28, 2018, 18:51:10 by johnu »
Offline teazer
« Reply #1329 on: Sep 28, 2018, 19:32:21 »
Sounds really close - crisp exhaust note. Sounds like a slight rich stumble as you ride past.
How does it run?
BTW, what are the mufflers?  I don't remember.
« Last Edit: Sep 29, 2018, 13:57:25 by teazer »
