Author Topic: Ugly Punx XV1100  (Read 23557 times)
Offline Brodie
  • Gold Coast, Queensland
Re: "Vicious" Ugly Punx XV1100
« Reply #110 on: Apr 06, 2017, 03:48:51 »
That or Loch Hampton.
Bought some foam to shape my new seat out of today. Went with fairly high density stuff to build up the seat and then some high density stuff for comfort. Bloody spray glue cost more than the foam did and I am sure I won't use all of it.
Offline advCo
  • Nick Ol' Eye
    • adventur Studios
« Reply #111 on: Apr 06, 2017, 04:01:15 »
I like the thought of green, maybe yellow but dark green and gold might be nice.
Offline Brodie
« Reply #112 on: Apr 06, 2017, 08:52:16 »
Yep, that is one of the styles I was thinking. Just not sure I want to paint until I decide on the tank I want.
Offline Brodie
« Reply #113 on: Apr 13, 2017, 02:56:26 »
Nearly done with the new seat foam. I know it is going to look of with such a large area of vertical seat cover but I am hoping this will be broken up by the two different colours used in the cover.
Still need to do a bit more shaping and put the smoothing foam over it but at least it resembles the shape I was after. Not bad for my first seat I think but then I am bias.
Offline canyoncarver
  • 'hacking is learning'
« Reply #114 on: Apr 13, 2017, 17:28:08 »
I dig where you are going with it.  Trim that seat lower edge to fit more of a frame line.  Maybe do a faux oilbag as sidecovers.
Offline Brodie
« Reply #115 on: Apr 13, 2017, 20:07:52 »
Thanks. I was thinking about trimming the pan, my only concern was losing some of the strength. I will have a closer look and see how much I can remove but as you can see from the first pic there is not much to be taken away.
My other option is to build an extra subframe. The current set up is quite comfortable, I have taken the grey foam right to the pan at the back just to get my placement further back.
Due to the rear sets and low bars not much weight is on that area.
« Last Edit: Apr 13, 2017, 20:12:14 by Brodie »
Offline Brodie
« Reply #116 on: Apr 16, 2017, 23:36:47 »
Just a quick picture update, sorry for the bad photos my phones camera doesn't deal well with shadows.
Rear sets fitted but not finished. I still need to adjust heights a little and a few more fittings.
Offline Brodie
« Reply #117 on: Apr 18, 2017, 18:29:16 »
New carbs and fairing arrived today. They are very nice and I can tell they are both from the same mold. The fairing is quite nice as well for a Chinese unit but a little bigger than I expected.
So I have been thinking about paint and decided I do want to paint it dark green. I had a crazy idea about using chalkboard paint but it is brush on so I might give that a miss.
As for the seat cover. I want brown on the seat and had thought of using a brown panel in the centre of the seat. I am now thinking of using brown on the outside with black around the lower section to try and hide the bulkyness of the seat. If I design the brown on the cover to only drop as low as the bottom of the tank and use black below that it should help. What is everyone else opinion.
Offline Brodie
« Reply #118 on: Apr 18, 2017, 20:27:44 »
Offline Brodie
« Reply #119 on: Apr 18, 2017, 22:36:39 »
Out with the old.
In with the new.
And the verdict is......       Front cylinder not firing.
So as this is my first bike that isn't a thumper I have a question to those in the know. Will the idle being different effect if the cylinder fires or not?
If it is not fuel the next thing will be checking the coil, which will be new to me as well.
Dummy fitted the fairing as well. I am not sure on the height. I might get some headlight ears and a new headlight if I don't like it. Otherwise the bike is heading in the direction I had hoped for.
