Author Topic: 1973 DT250 Cafe/Brat build  (Read 8585 times)
Offline Giancarlo124
Re: 1973 DT250 Cafe/Brat build
« Reply #20 on: Jan 08, 2017, 20:27:08 »
That brace will do the trick :)
probably will mount the fender from it too
The Oil Burners:
73 Dt-250
66 YM1 305
09' jetta TDi
Offline Jachana
    • 1980 CM400
« Reply #21 on: Jan 09, 2017, 11:46:21 »
Nice Brace. I had one on my RT3 and it worked nice. I don't think I can run one on El Chivo because of the larger front tire now but I may just try.
Looking Great man,
Jachana
1980 CM400 Cafe
1976 Goldwing "Goldfinger"
1973 RT3 360 Resto
1973/77 RT3 "El Chivo"
« Reply #22 on: Jan 09, 2017, 12:17:24 »
Looking Great man,
Jachana
Thanks man. loving your build as well. I think i will have to modify the mounting holes on the brace as it comes a little too close to the larger and lower headlight.
The Oil Burners:
73 Dt-250
66 YM1 305
09' jetta TDi
« Reply #23 on: Mar 14, 2017, 12:01:03 »
Been a while since I checked in here but I have gotten work done on the bike. I finished making new clutch, front brake, and throttle cables using the venhill cable kits that can be found on ebay. I also got most of the wiring harness finished, all I need to do is but some lights and wire them up. I put a new mikuni tm32 flatslide carb on. And I bent up a new kickstart lever cause the old one bent when the motor kicked back. Next week I will start modifying and fabricating an expansion chamber
Some of the wiring
Front brake cable
The Oil Burners:
73 Dt-250
66 YM1 305
09' jetta TDi
« Reply #25 on: Apr 27, 2017, 22:27:11 »
Cool project man.  This is going to be great!
Thank you! Glad you like it
The Oil Burners:
73 Dt-250
66 YM1 305
09' jetta TDi
« Reply #26 on: Apr 27, 2017, 22:28:36 »
I sent the seat off to get upholstered and got the pipe mounted, more updates coming soon!
The Oil Burners:
73 Dt-250
66 YM1 305
09' jetta TDi
Offline jimmer
« Reply #27 on: Apr 27, 2017, 22:49:11 »
Looks good. What is the pipe? Did you port the cylinder, Boyesen ports,any trick reeds? Great carb choice.
Yamaha Blaster Bike        Suzuki T500 Titan Twingle Yamaha XT 225
« Reply #28 on: Apr 27, 2017, 23:07:48 »
pipe is an old one i found on ebay that i modified the header tube to go down, i kept the length right so it should be pretty decent (cant be worse than the stock pipe). No porting yet. has boyeson 603 power reeds in the cage, tm32 mik carb. And I have a GYT high compression head that will eventually go on. Glad you like it!
The Oil Burners:
73 Dt-250
66 YM1 305
09' jetta TDi
Offline brad black
« Reply #29 on: Apr 30, 2017, 00:48:00 »
some light reading for pipe design on the dt
http://www.bridgestonemotorcycle.com/documents/do_you_really6.pdf
