It's not as bad as an actual TZ, but it won't have a lot of bottom end. That said, jetting and ignition timing can make a huge difference. But it will never be like a big fat 4 stroke. My RZ is basically stock and the power valve allows it to run cleanly at lower revs, and then it wakes up around 6 or 7K.
No need for the clutch on up shifts. just back out of the throttle to unload the gear dogs and slip it into gear.
What jetting is in those carbs? You might want to ask over on 2 strokeworld about jetting TM series for an RD or LC. There's a lot of experience over there.
If your ignition has a tacho output, try a different tacho. I found the trailtech to be really cute, but not much use when thrashing up the street. If you have a CDI ignition, you need an adapter to pickup up the high voltage signal from the CDI to coil and convert it into a suitable wave for a regular tacho.
I see that Spike has a Koso tacho on that TZ, so he may be using a modern programmable ignition.
