'75 cb200t cafe build
blkcorvair said:
where'd you get the pieces for the exhaust sytem?
the collector, springs, and spring clips came from Cone Engineering and the mandrel bends and tubing came from Specialty Products Design (SPD). Another good source for bends and tubing is Columbia River Mandrel.
Stik
Stik,
That design dates back to the earliest Hondas which all used a pair of rubber wheels to tension the cam chain. the tensioners are often overlooked and it's a worn chain that does the damage.
What they need in a perfect world is a complete re-design to take a flat blade on the exhaust (tight) side and a curved blade on the intake (slack) side.
It might be possible ( I have not investigated it), to modify one of those flat tensioners with Nylon/teflon rubbing block that people like Bore-tech and THR sell for the CB350.
I even cut a hew heads open to see what could be done to fit modern design parts in there, but the jury is still out.
When the head is off, loosen the lock bolt and be sure that the tensioner shaft is free to move up and down in the head. They develop a raised part where the bolt tightens up and that leads to a false sense of when the chain is correctly tensioned. I tend to push on the end of the tensioner to feel it springing against the cam chain to be sure.
teazer said:
Stik,
What they need in a perfect world is a complete re-disign to take a flat blade on the exhaust (tight) side and a curved blade on the intake (slack) side.
I even cut a hew heads open to seel what could be done to fit modern design parts in there, but the jury is still out.
When teh head is off, loosen the lock bolt and be sure that the tensioner shaft is free to move up and down in the head. They develop a raised part where the bolt tightens up and that leads to a false sense of when the chain is correctly tensioned. I tend to push on the end of the tensioner to feel it springing agaoinst teh cam chain to be sure.
Thank you for the reply. I now know I'm not crazy ( at least with this issue ;D)
Another hot day in the midwest. Took one of my Triumph's for a ride through town to cool off. I built this one two years ago. I got my clip-on bars a little closer today. Tacked them and need to cut a tack and move one side up. Will use the angle finder while the bars are on the bike this time ;). Hopefully can get the shift linkage finished Tuesday and start on exhaust. (Junk engine in picture for mock up)
Super clean bike so far! Whered you get the spokes? Im thinking of relacing my stock 175 rims & hubs with some new spokes.
Keep it up. Love the gold
Awesome CB. The way it is turning out is the vision I had in my mind when I saw and bought my CB200 (Also a gold '75...). I can't compete with that, nice job - I love it.
Lookin' good Stik! I'm back from Vaca and have the 200 tank soaking in degreaser, metal ready is next should be nice and clean after that!
Bikes look sick....Noticed the COC sticker, then the Iowa plates. Where at in iowa you located?
thanks man! the spokes are the stock ones. The cadmium plating was pretty decent on them so I just polished them on the wheel
I got the clip-ons pretty well finished up and am happy with them, just going to weld the inside holes shut. Started on the pipes and am pleased with the way they are coming together. I have the lower bends cut to length. Won't be long and they'll be complete to the back side of the collector. Not for sure which direction I'm going with the cone yet.
Keep me posted on them pipes dude. might hit you up for a set?? I wanted to do what you are doing for mine but got overwhelmed a bit. also, I'm a novice welder. Well, and I had a couple sets of cl pipes.
Had a good day yesterday. Got the collector fitted and welded. Pretty happy with it. It will be a right exit with a shorty reverse cone megaphone when finished. Need to order the megaphone today.
Lookin great Stik!
Any particular muffler you are looking at? The one I've used the most is from JCWhitney - reverse megaphone with a removable end cap. That way you can mess with the baffle without taking the entire muffler off.
Big Rich said:
Lookin great Stik!
Thanks Rich, On Friday, I ordered an Emgo shorty reverse cone. I believe exactly like you're talking about. I have some old Triumph MCM pipes for a 500 I'll never use and will use them for the bends.
