Sonreir said:If you unplug both wires, then the wire with voltage is the hot one.
Ryan Stecken said:Thanks bruno!
Its definitely a wasted spark system that i know for sure.will call the acewell support line and let you know the result.
MotorbikeBruno said:Rock on, worst case, that link I gave you is the acewell forum![]()
Ryan Stecken said:Hey guys!
Long time no hear.Took quite a while for me to be able to fool around again with the tach, i was converting my RD to 350 and and and...
So i still have one big issue with my Acewell Tach: Everything works fine except the revvs.
I tried every pulse-setting on the tach (2r1p,....)none of them shows the right revvs when i revv the engine.Idle revvs seem to be right.
I read stuff about people soldering resistors into the wiring?
Any help appreciated!
MotorbikeBruno said:Maybe a little more info for us to help better. Idle appears ok on ONE setting, or all of them? What does the tach do when you rev it up? Can you hold throttle say at 4k or 5k (guessing since your tach doesn't work of course...) and does it hold or bounce all over the place. Give as much detailed info as possible for these kinds of questions since we aren't there and can't see what's going on![]()
