Acewell MD052 Tach Question
I've never used one, myself, so I can't say. Searching the 'net turns up a lot of different options though.
Ryan Stecken said:
Yes i did,the acewell generally has idle rev correct but when the motor gets revved up the acewell tach shoots trough the roof.
Sonreir, it's not as smooth as it should be. I can see what he's saying and it's not how it should be acting. (or at least mine didn't run like that, it was "more smooth" than that, given it goes in 100rpm increments)
Ok lets go over the basics to double check. Method using again? White wire to CDI, or yellow wire wrapped around plug lead?? I did a few more turns than they said to on mine. (more like 5-10 turns) Note that it goes in 100rpm increments of course, so it's not "smooth" per se. ALSO, if you have INSULATION or thick extra sheathing on spark plug wire, it cannot read well. I had to strip a two inch section of that insulation off so it was wrapping around JUST the spark plug wire.
From the manual:
2. Tachometer signal can pick up from either CDI or Sparking plug we
suggest to circle round 2-5 turns on CDI or Plug cable.
3. It has 2 wires to pick up RPM signal, the yellow wire is to connect to
Plug, and blue wire is for signal from ECU or Ignition coil, only use 1
of the wires.
Then in the second section:
RPM sensor mounting: RPM Input,
1.Connect either the yellow or white wire to sense the RPM signal.
2.The yellow wire can be wrapped around the spark plug lead.
a.Signal intensity from ignition coil is dependent on vehicle type.
b.Coil 2-5 turns around spark plug lead, with more turns creating
steadily stronger signal, fewer turns creating weaker signal.
3.If the yellow wire be wrapped around the spark plug lead works not
stable, please try to connect the white wire to either the ECU rev
counter output or to the primary side of the coil.
Next we have this section when you set the rpm setting. I would make sure you know what the redline is on the bike too!! and set it 500rpm before that! I'm assuming you are 1r1p or 2r1p BUT it's entirely possible to have 1 rotation with 2 pulses if it's 180 out...so 1R2p could be another possibility. I don't know RD's so I apologize on this one. I haven't researched your bike yet
4. It displays the default "r06500 RPM", the digits “06” flashes. Follow the item 2 of button operation to finish the shift RPM warning setting and jump
to engine specification setting.
5. It displays "SP 1r1P and RPM", the default value is 1r1P; there are 5 options: 1r1p, 2r1p, 1r2p, 1r3p, 1r4p. “r” means the numbers of engine
rotation, “P” means number of signals from engine. For example the value 2r1P means the engine rotates 2 turns to output one signal.
6. Press the button to move in loop sequence from one to another value of the 5 values. Hold the button to confirm the setting and go to wheel
circumference setting screen
Not sure how relevant, but it sounded like something on topic...I took this from another forum about RD's, a guy said:
MZB has one coil with two outputs. Both plugs fire at the same time, a wasted spark at the bottom of the stroke. If your tach just counts sparks, it would read twice the real speed, or even four times if it isn't set up for a two stroke. One time, I borrowed a friends strobe timing light to troubleshoot my MZB, and the light just gave up at about 7K, because it was getting so many sparks. If on a conventional iggy on a four stroke, the engine would have had to turn 28K to spark at that rate. Interesting to think about. Maybe that's what's behind your tach problems.
Reply:
read off one of the AC charging lines (black wire going to the regulator). set gauge to 12 cyl. yes it works and its massivly responsive. :) had the same problem with my SPA, that fixed it. no rf problems
Some said noise from spark plugs could cause it? He wrapped his yellow lead in tinfoil tape or something to help block the extra signals. Just another thought..and it's cheap! And if yours has the wasted spark at the bottom of the stroke, it would be 2 sparks per revolution correct? Bringing us back to 1r2p maybe?
