Another cb 360t, but with a sexy twist.
Thats awesome. a pinch of dieselpunk tossed into the batter, spices her up in a good way.
That is really something else.. Good thinking!
Sent from my Galaxy Nexus using Tapatalk 2
haha thanks! :D I finally welded the panels onto the cowl here is what that looks like...
Definitely going to smooth this with bondo but it is coming together nicely...
Are you going to be leaving the hexagonal shape of the cowl or going to be making it spherical? If you are just cleaning it up and keeping the edges and lines, bondo will be fine. But if you are going to make it round you might want to invest in dynaglass before you use bondo. Bondo isn't really made to cover thick areas..
I Agree with Ronnie.
However, I think it looks really cool with the panelled shape you have from framing it in wire first. Looks really cool against the lines of the tank!
Keep going!
Think its pretty clear that shes going for that shape to flow with the tank, then bondo'in the imperfections and rough spots smooth not to alter the shape at all.
Love it so far cant wait to see it done
yes I am going to try and improve on this rear cowl and do an octagonal facet look with rounded edges to match the geometric look of the tank
Before you apply any filler, get a good air grinder with some 80 grit discs amd shape the seams. Smooth it all as much as possible.
Re: Re: Another cb 360t, but with a sexy twist.
Second that.. Flap wheels work good too.
So I have some finishing touches on the seat and tank, the seat I added some bolts to have a secure mounting system which go through the tabs on the frame
I also ground the seat with a finer grit... so the glare from the seat makes it hard to see the details...
  • seat w: studs.jpg
    seat w: studs.jpg
And I also mounted my tank using a hinge and some bolts makes it easy to take the tank off..
That final bit is a nice touch. It's always a bit of a pain in the ass to get the tank on and off the 360s.
