CB360 - Monoshock Brat
You may also find that you can put the business end of a grease gun into the brake line fitting and force the piston out. Doing it with compressed air has always given me the jitters, but I try not to use high-caliber popguns in the shop.
I made a fitting for grease gun to caliper 30+ yrs ago. (used to do a lot of them, particularly as they were almost new at the time ;) )
Made a new one about 6 months ago as I forgot I had it, then found the original ::)
Makes life really really easy (so easy it's boring ;) )
a fun way to remove stuck piston (in a real dangerous sort of way) is block up all the holes with bolts and copper washers then heat it up with a propane torch until fluid boils ;D
Piston will travel at least 50 ft or more
7alive, he doesn't ride very hard or would have already found the limitations of running without a fork brace,plus, that pic isn't a 110 tyre on front
BTW, does anyone know which GM car uses the 1.5" phenolic piston? ( I like the idea of lightweight, non corroding, low heat transference brake piston)
Re: Re: CB360 - Monoshock Brat
None that i know of, but there is a guy over in SOHC4 that is turning them down from Toyota pistons. I bought two and they are perfect and only about $30.
I know they need shortening, Toyota must be cheaper than GM as they were over $30.00 each before machining
It's a bit surprising that Honda used so many imperial size parts in the mid 70's? (1/8" Whitworth thread spokes was a real shock ;D )
I was getting excited about fabbing up a leg guard for the exhaust. I got this far then did the rest in photochop. After seeing this I'm leaning towards fully wrapping the pipes instead of going with a guard. Any thoughts? Would wrapping the headers give me much better performance with the 2 into 1?
I love the leg guard - do it!
Really suits the mad scrambler look of the bike.
You might want to do more holes and a bit smaller though.
Thanks for the encouragement everyone. It took me nearly all day to finish up the leg guard but I'm pretty happy with it now. I pounded the shape a little thinner towards the end of the exhaust and countersunk the mounts. I kept wasting time in photoshop trying to mock up a hole pattern that looked cool but in the end I just started drilling until it was covered.
Thanks Mike. There was a slight method to my madess I just didn't drill straight enough. :P
