CB400T Café Build...but be patient this will take a while!!
http://www.dotheton.com/forum/Smileys/default/cool.gif
Managed to steal some free time this weekend and get stuck into the bike, mainly working on the wiring loom, when I was getting the tank made, I forgot to leave the Cdi unit fitted hence, not enough room now on the opposite side of the frame to the coil to fit the Cdi, so that now has to be moved back down under the saddle, no major problem just extended the connector block, soldering the joins to be sure to be sure, as they say here in Ireland.....I also found some cloth tesa tape on fleabay and have finished off the loom from the headstock back to the battery....some pic attached...I also managed to get the engine running over the weekend albeit badly,and on used oil...ran for about 15 minutes very very rich,,,exhaust note is nice...but lots more work to be done..oil dropped now.....so need to concentrate on the build again....I have worked out a mechanism for the rear brake...and intend to get that fabricated up this week sometime....if that works, I will need to then figure out how to run a brake light switch...
New headlamp and fork gators arrived last week, waiting for the speedo & rev counter, so I can complete the loom.
Dime City Cycles delivered these little beauties today...the wiring instructions for the tacho were incorrect....green wire goes to positive on the coil or cdi, not ground as stated in the instructions, I have informed the guys a DCC, so hopefully they will save the next customer the extra work in trying to figure it out....the tacho is pretty cool all the same, on power up it cycles from zero through to eight and back to zero again...just like a superbike...wow my café racer will have some street cred.
The wiring is still a mess, but at least now everything is connected up and working, so I can starting tidying it up now...and remove all the un-wanted and un-needed clutter.
Hi. How are you going to connect your rear brake to the rear set? Will you use a spring and where will your brake light switch be?
Looking good so far.
I have a brake rod made up...with a spring used in the same way as the original set up, I'm not 100% sure how I'm going to rig up a brake light switch at the moment, I need to find some more time and get stuck back in, have not done any work in a while...I will try and get some posts up in the coming weeks.
My Bike uses the same frame as yours.
I have a generic plunger style switch mounted to a tab on the rear hoop section of the frame. A spring attached to the brake lever at one end and the plunger switch at the other activates the brake lights. The switch is adjustable for sensitivity by screwing it up or down in the tab.
I am running side covers though. I don't know how neat you could make it on your setup with an open frame.
Nicko
I am away for work untill the 23rd. When I get home I will snap a pic for you.
The switch is very similar to this.
http://www.ebay.com.au/itm/Emgo-Universal-Brake-Light-Switch-Rear-Stop-Spring-Pull-Motorcycle-New-K-S-/300953374566?pt=Motorcycles_Parts_Accessories&hash=item4612380f66&_uhb=1
Nick
DrDuke,
Great build!! I been in the process of building my own 78 HawkT2 and I was wondering about replacing the Keihin Carbs as well. Can you tell me a little more about the model and the set up that you are running.
Thanks,
78HawkII said:
DrDuke,
Thanks,
Sorry for the delayed response, just don't seem to be getting much free time these days, and to top if off, I broke my finger last week, so that will delay the project even further....I purchased my carbs from Lossa engineering, they are Mikuni VM32, they are working very well, but will need to be re-jetted, as I have changed the exhaust system completely, and the carbs out of the box are set up for a 350cc not a 400cc...see link below to the website.
http://www.lossaengineering.com/shop/mikuni-vm32-carb-kit/
Eoin
got some time this weekend, wow this is turning into a epic build, I managed to finish the wiring, totally stripped down of unwanted stuff, indicators, ignition substituted for a 30amp on/off switch, fitted a break in the loom under the the petrol tank, this keeps the wiring around the headlight to a minimum, battery, regulator and cdi all located under the seat, will try and get the seat covered next, and still need to sort out a rear brake mechanism to work with the universal rear sets, then I should be ready for powder coating, and a final built.
The Tank was a custom made tank, its based on a slippery Sam Triumph Trident race tank from 1970, the pipes
are from a bonneville carb model...
To be sure ya build gonna be a head turner this summer 8) sure you'll get it finished up for then , real clean look goin on :P ya got class mate ;) ime a fan of this one all the way ::) keep goin mate , always here for Q & A's doubt ya need inspiration :o
Cheers Yorkie, glad you like where I'm going with this,
hopefully I'll have it on the road to enjoy for the Summer.
Needed to do a seat mod, as I had extended the frame hoop, due to the pipes sticking out a little further than originally planned, will be recovered over the weekend, so will post early next week some pictures of same.
Now, all we need to do is pop a nice seat covering on there, and some foam to comfy it up a bit.
