Took a long look for air leaks this morning, all the rubber parts are flexible and seal fine.
spraying wd40 about found no leaks
so i wanted to check the carb mechanism/throttle cables
both cables were new last year but the pull cable was always a bad fit, too long and not enough adjustment, and it seems a bit stiff to return.
inside the twistgrip there is a little kink in the cable Which might be dragging.
so i‘ve ordered a new pull cable from David Silver in the hope it might fit and work better.
what‘s the procedure for lubricating the carb theottle closing mechanism so it closes reliably?
steve
