NoRiders
Over 1,000 Posts
Fit new plug leads they said, it won't take long they said!!!!..
Well, a whole evening to change 4x plug leads...talk about taking my time. All I had to do was strip off the old leads of cap, coil screw cap and lead sleeve and then slide them all onto the new silicon leads. They're only circa 1mm wider, no problem on a test fit.
However, trying to do all 4 the rubber sleeves were tighter than a tight thing, well lubed with vaseline and WD40 I couldn't get the new leads through the lead marker ring of plastic on #1 lead. tried warming it and gave it a good go, but it would not pass through the marker ring....bugger.
Had to split the rings three times.
Not too sure they'll glue back in place and I rather like the idea of having the factory markings with just a bit of orange visible.
I have a plan, I've ordered a 1:72 letter/number transfer kit for RAF model planes. There's a good selection of font sizes on one sheet. I plan to use new shrink wrap with these numbers stuck on to replicate the OG markers....hope it works? :-/
Here's a few snaps.
The orange looks dull in these images, poorly lit I think. They're actually very bright orange haha!.
You can see #1 doesn't have markers....
With the tank in place, there's just a sneaky splash of colour, caps all facing the same way and outer sleeves the same distance from the cap. They better bloody work, I tell ya.
Only a small cosmetic job, but immensely satisfying....I also cleaned & degreased both handlebar control units and most of the loom/connectors. Nothing to see.....
Thanks for checking in..
Here's a few snaps.
