Well as I said, I would have the back wheel in by today and that would open up a whole new ball game.
This afternoon I'm going to heat wrap my exhaust. I set it up on the bike, then drilled a couple of tiny hole to pt self fappers in to hold the position. Then I dropped out the complete unit
Once I got it in the vice I sawed off the inside clamp lugs
Then ran a file over them to take off any sharp edges
I'm going to use this stuff to seal the joints
one at a time I removed the screws and smeared the paste around the pipes then slotted them back in and smeared some around the outside.
Then I used a heat gun to dry it off
Now if you are going to try this, you'll need gloves because this stuff contains fiberglass, and you'll itch bad.
You'll also need stainless steel zip ties
And a bucket of warm soapy water to soak the wrap in so it expands, then contracts when it drys out and tightens around the tube.
soak the wrap for a couple of minutes, the soap is a wetting agent and will help it to soak a bit quicker than water alone.
Next start at the bottom of the pipe so the wrap overlaps face backwards and dont catch road grime.
Start with one full turn around the pipe and tie it off with a zip.
Then wind it on over lapping by about half, and keep it pulled as tight as you can
Work youre way to the top and tie it off with a couple of zips
Then do the other side the same way. I also did the section between the can and headers.
Once I got them back on they looked far better
And there we are, another job ticked off the to do list.
