Took a couple of hours in the shed this afternoon as a mechanism to get over a mild hangover. Project for today: see if I could make a number plate bracket.
I have a bit of 3mm Alu here so thought I would use that to make a template. In the end it worked out quite well so I may keep it as it is and simply powdercoat or paint it like the frame.
I had an old subframe tray that I had already replaced, so I cut the back off it and used it as a mount.
Version 1 (test of concept and angles):
Test mount on the bike:
I checked the wheel clearance by removing the spring on the shock and checking the rear wheel travel. It's close, maybe a bit too close so I decided to have another go, sharpening the angle it came out the back and also put some flaps on the bracket so I could actually attach the number plate.
Version 2 (a bit more complicated), I cut them all out with the angle grinder and formed the shapes with a carbide bit in the Dremel, a file and a flap disc.:
In the end I made a mockup of a number plate to see what it would eventually look like. Not bad I think:
