Well it turns out the new fender I bought doesn't fit properly. Something I thought about before I bought it as I had the option of making some custom lower brackets. Turns out it was mounting too far away from the fork leg causing issues with clearance at the back.
So today I decided to make some brackets. First I grabbed some MDF and cut analogues of the current brackets to see if I could simply redrill some holes:
This is where I worked out how to make sure the fork legs cleared the fender and also got appropriate clearance between the fender and tyre.
Next up was to redo the brackets and mark up the holes, here they are compared to the original brackets:
I wasn't going to make the brackets as I was thinking of giving them to a buddy of mine with a CNC mill, but I had some 4mm Alu here that I thought I would at least try and see if it worked:
I drilled the bottom holes and tapped the top ones:
Mounted:
And done. Pretty pleased with how it's turned out, just need to lightly brush the brackets and they should be finished:
Tyre clearance is much better too:
I have the bike up the top end of the garage so I thought I would get it out for a proper side view to start getting an idea of what it's going to look like:
The stance is a bit funny as the front is off the ground. Won't be too long before it sits on its own though.
