The KZ440, rated at 40 h.p. at 8500 r.p.m. and 26 ft. lbs. at 7000 r.p.m.
is only 82% volumetric efficient at max power. That does not mean it is not
efficient at lower speeds. Intake port entrance measures 31.6mm compared
to 32.6 for the KZ1000J and 29.4mm for the KZ900/1000. Valve size is
35mm/intake and 31mm/exhaust. KZ900/1000s uses 36/30 valves.
Compared to the GPz1100 Unitrac head on bore and cylinder size it is just a
smaller version. Cam timing is 27/73 intake and 70/30 exhaust for a 113*
intake center line. Compared to the KZ900/1000 with 30/70 and 70/30 with
a 110* intake centerline the 400/440 intake is retarded 3 degrees. KZ650/750s
have a 105* centerline. These little engines have good port flow. They need some
help with cam timing and cylinder pressure.
As for carb size the most 440 are over carbureted. Cylinder volume of the 440
is 221.5cc compared to the 900 at 225.75cc which makes 20.5 hp/cylinder
with a 28mm carb vs. 20 hp w/ a 36mm carb for the 440. The 900 also has a smaller
port and compression ratio.
To advance the cam there are 4 options for the 440 that are strictly bolt on. One is
just advancing the stock sprocket 1 tooth for 15.65 degrees.
113-15.65 = 97.35*
98* is typically the farthest most people will advance an intake centerline. There is
probably some cam chain stretch to take it past 98*.
The other 3 options use the KZ750/4 cam gear for a guesstimated advance of 5, 7 and
13 degrees. The hole with the square is 5* and the white tooth next to the Z7EX will line
up the arrow on the stock sprocket. The octagon hole is 13* with the Z6EX tooth. The
round hole is 7* with the IN tooth. As for cranking compression with these settingsare as
follows on this engine, Measured with a different gauge than before because I think it is
more accurate. I was leary of freshening up and having the rings not sealing at first and
then breaking in throwing of the results. When I do a degree wheel will also be utilized to
document those specs.
Stock --- no. 1/2 165/155
5* ---- 163/170
7* ---- 160/172
13* --- 171/180
15.65* --- 180/187
Also note the end of the cam. I scribed a line for a reference. The notch will also work.
The more the cam is advanced the more those marks will rotate counterclockwise.
And don't let your advancer get this bad.
