DTT Barber Build 2012
Thanks. When I was building her the first time I got a 750f tank and could not get it to fit over the large upper frame tube without lots of cutting and welding which is what drove me towards designing my own tank.
Is the cb750f tanks tunnel not deep enough? What is the issue. I know I have some pretty narrow tanks I have been able to make them fit over the backbone on Jenns bike. The current tank I just grabbed that sucker like a man stretched it open till it cleared the engine mounts.
The top of the tunnel isn't wide enough to fit the large dia. tube up into it. The cb750 frame has 3 smaller tubes under the tank. I was afraid to just beat on it to get it to fit as I thought I might punch a hole through it.
I saw Mr. E's tank this weekend and liked the lines. Just trying to figure out if I should even consider it. I think the answer is no.
Aren't the lines the same pretty much for a cb450 tank? Looking at 70's 750s they look pretty similar.
Yes, I think your right, they are very similar, depending on which year 450 tank you look at of course.
If I'm not mistaken, Rich has one of the 450 tanks you're thinking of...and I do like them a lot. They have a rad stock body line.
Sent from my DROID RAZR using Tapatalk 2
I been staring at the on that is going on my 450, that's why I had to ask. ;D Its a MESS but will shape up one day.
Something like this?
http://www.ebay.com/itm/HONDA-1971-CB450-K4-NEW-NOS-GAS-TANK-Candy-Gold-Black-/360462667879?pt=Motorcycles_Parts_Accessories&hash=item53ed3fd067&vxp=mtr
Tear down is almost complete. Had to get a little clever with the boards and paint cans but I got it apart by myself.
Yes, they are similar. I was actually thinking about something "softer". Rounder like in my dwg. Talking to Rich about his 550 tank.
@John, I plan on getting there Thursday night.
Flug, what's the diameter on your frame tube? I have a '75 CB750K tank here that I can get some measurements from for ya.
I don't know, but I had a 750f tank and it would not fit. Rich is sending me his 550 tank to try out. We will see how that goes.
So I had some good news tonight. I had gotten a pamco electronic ignition about a year ago and tried to install it this spring. I couldn't get it to work. I tried everything. I recently sent it back to Pete and he sent me a new one. I hooked it up tonight and the bike fired right up. So now we will be adding that to the list things to install at Barber.
Re: DTT Barber Build 2012 - Frame Fixable?
I got the engine out of the frame last night and was able to take a good look at the damage to the frame. Besides some paint damage it looks like the frame is still good and straight with the exception of the location pointed out previously.
It looks like the frame tube was crushed when it hit a rock and the frame is bent up slightly. This location is underneath the engine between the forward engine mount and the mid lower engine mount. Looking at the pics below you can see how much is bent up as it should be sitting flat on the ground like the other side.
So, can this be repaired? How? I was thinking the frame could be bent back into position, and then a piece of tubing could be welded on over the crushed part to reinforce it.
I would like to try and save this frame since it is already titled, registered and insured.
It doesn't need to be pretty, just functional.
Thoughts?
Engine in for reference:
Sheesh... That frame is scary man.
Ok, I want to publicly apologize for not getting you the gas tank and pegs yet. I PROMISE that Ill get them out to you asap!
Sorry... :(
I'd almost think it would be best to get a donor frame, stamp the VIN from the damaged one onto the new frame and scrap that one.
I would agree with Tim, the front union looks twisted in the side shot showing how the tube is lifted from the impact. I would bet that if you put that frame on a frame table you would see that it is tweaked more than just the collapsed tube. Play it safe and find a donor bike without a title and swap and restamp. Cheaper in the long run and safer too.
Where is the VIN on the frame? On the neck? I think that's the usual spot. Why not just swap necks on a donor frame? That can be done, right?
