Father Son 75 CB200T Rise From the Ruins
I used an bench grinder to remove the larger casting marks and then a dremel tool for the detail stuff. Finished off with sanding using 60, 80, and 120 grit paper. Polished it was black emory just for the heck of it. Took a few grams from each one, I reckon.
that looks like more than a few..like 5g :) in that pix it looks like they were reduced in width by a mm on ea side. It would seem you wouldn't want to score them in the direction that would cause a stress fracture???
You know... I'm not too sure. I would think polishing them might relieve any stress points, but maybe that's wishful thinking?
We discovered Why we are running rich at high RPMs! Can you tell from the picture? There is only one difference between an 18mm keihin and a 20mm keihin.
The cb shop 175 manual is amazing. It is a tutorial on why it works. We highly recommend reading the 175 manual before the 200 manual.
jacques said:
love the thread, love what zekes thread is looking like also, you're a great father keep doing what you are doing!! :D
that is very kind of you we are having a blast!
We are going against the grain with our valve sizing. We are
going to the Dyno with stock 28mm intake and 24mm exhaust with the current mods to the valve train, porting, lightening, compression, OCD on titanium tappet nuts that we will find cheaper than 10 bucks each. Then we will try a 23mm exhaust. We have plenty of stock valves to turn and then maybe 22.5mm. According to AG Bell this is the optimum for velocity and our cc.
It doesn't make any sense to go up in valve size, stainless, etc all add weight to the valve train. We have been studying the crf 100 and crf 150 along with Takegawa and Kitco and their kits seem to follow Mr. Bell to the V.
If this proves prudent on the Dyno then additional valve train lightening can be achieved with smaller stem exhaust valves.
On one of our motors we had the valve adjusting screws drilled out and broached for an allen wrench. I don't have scales sensitive enough to measure that saving but I never did know where to draw that line that says - Enough. Stop.
LOL!!! I have been looking for a more sensitive scale!!!!I remember your post about Pops Yoshimura for that mod..i want to get rid of the nut then we have a 100% weight savings. Will blue loctite hold it or would we need to use red?
I like the thought that failure is in the equation for success...like counting how many times you sand down your frame like Burt Munro and then after it fails back off a couple of strokes next time...
That's how I work with rocker arms - there's a lot to come off them and they snap if something breaks which reduces damage. Had a cam chain wheel disintegrate at Phillip Island at about 110+ on a 350. Valves bent, rockers snapped and pistons, rods and head were fine. Cheaper than bludgeoning the head and piston to death.
As you may know by now...I want my son to learn how to be frugal and do more with less. We have had a heck of a time finding cb200 cams... and the ones we did find there was no way we were going to pay that much. We buy the 1.62 cough syrup not the name brand for 7.00
Is there any reason why we can't run a cb200 cam spocket on a cb175 cam with an adjustable pressed on adapter like capallenis? Then we can swop back and forth cams between engines by just changing a sprocket....
We now have 4 cams around here to play with...we would like to keep the 200 cam stock...we need a baseline for statistical analysis :)
Does anyone else machine an adjustable cam sprocket?
Kop...working on it. I have to keep this project within budget. Well keep it within the appearance of a budget. :) that is why I don't pull the trigger right away but I am listening.... "Do you have a hydraulic press yet" and I guess we will need a drill press also lol.
Do we need to use a tapered reamer? The existing holes do not look tapered...
Press the sprocket off and press it back on is one way to do the deed. Or get an adapter machined. and pressed on and then slot your 200 sprocket. 160 and 175 cams have different sprockets and cams, but it's all doable. Bateman used to sell an adapter. I had to get a sleeve made to use a 200 cam with 175/160 sprocket - don't remember which I used now.
BTW, two bolts are enough to hold a cam sprocket, but use Honda shouldered bolts if you can get them. On a CB77 I use two short cap screws and they never came loose or chattered with full drag race cams (bricks on sticks).
I don't understand the comments on that web site. Camshafts are all machined to take the pressed on sprocket. CB200 sprockets are larger OD than 160/175 and have 2 more teeth.
CB200 cams are probably cheaper than any/all of the above. See if you can get a complete motor for spares from a wrecking yard. They used to be dirt cheap - but that was before the cafe racer craze raised prices for everything.
Each rocker arm is 54g including nut and tappet screw. The cam sprocket is a 120 g.
acm177 said:
Yes, the head was milled flat. I cant' remember how much it was decked... off the top of my head.
your observation in this attached post just saved us from doing something stupid.
teazer said:
Different oiling on a 200 versus a 175. Cam needs to be modified - or the head.
would the 200 oiling lend itself to better oiling a ball bearing mod for the ears and cam?
