Keihin define "size: by slide diameter and Mikuni has a round bore and that is the "size". that means that a 20mm Mikuni will have a 20mm bore and 22-23mm slide.
Keihin uses a figure 8 bore so that at low throttle openings, it's basically a smaller diameter carb so gas velocity is high. When the throttle is all the way open the bore is elongated to be equivalent of a larger size. Very clever - almost a variable bore carb. And that was how they calculated the "size" it is the nominal equivalent diameter.
CB200 has a taller oval than a 175 and that's why it's rated as a "20"
Keihin also had a reputation for not "tracking" as well as Mikuni. What that means is that the overlap between circuits was harder to fine tune and they were harder to get smooth all the way through the rev/throttle range.
Keihin uses a figure 8 bore so that at low throttle openings, it's basically a smaller diameter carb so gas velocity is high. When the throttle is all the way open the bore is elongated to be equivalent of a larger size. Very clever - almost a variable boroe carb. And that was how they calculated the "size" it is the nominal equivalent diameter.
It really does come down to definitions...i am like Socrates favoring truth as the highest value but I guess this dialectic debate of the 20mm carb shoot out will be settled on the dyno :) which one will handle methanol better?
The mikuni vm20-273 is going to make jetting on the dyno easier. Green is the main jet, red is the needle jet, and green is the pilot jet. It would be a lot easier on the sand at bonneville reaching into a one piece fairing.
Maybe wishful thinking for our volumetric efficiency but the vm20 and pe 20 should more than provide our cfm requirements. Does anyone know if the 42.5 cfm numbers are correct for the mikuni and keihin 20mm?
We have been researching running methanol and as we understand it...it is like dating a high maintenance gal that carries a little dog in her purse. Wow the price some men will pay for speed...I tell my boys to run from high maintenance gals and here I am teaching Zeke how to build one. She wants twice as much fuel, is corrosive, and if she goes off on you...oh and all you have to do is keep her rich. So if we run 85 jets on a Keihin and 115's on the Mikunis where would we start with Methanol?
+130% on your main jet flow, so start at 2.5 times as much flow. With hex jets that would be a main jet around 290 or thereabouts. We ran jets over the 400 and I have heard of people on old Brit twins running up in the 7,8,900 range.
At least Methanol is a cheap race fuel. At $10 a gallon that works out to the same per mile as the U4,4 we've been using which is around $25 a gallon and is worth 2-5 MPH......... I may just go back to street juice. U4.4 is now up to $90 per drum. Ordinary M1 Methanol is only $6/gallon.
Try c25 at 130 per 5 gallon drum.............. And I guess that nitro is a lot more.
It's the old adage - how much do you want (/can you afford) to beat that record by?
BTW, that chart mentions that their carb size tool doesn't apply to IR (individual runner) applications like ours.
thanks for the help with the IR definition.
We are soooo making one like this! Of course it will say honda and we will use a honda motor cause we have access to blown up honda lawn mower engines...
Records are ultimately beaten by those who have invested priceless time into teaching the next generation. We waited on buying carbs for Lucky and it paid off in a massive education. We are turning Japanese oh yes we are turning Japanese...I really think so. At least we are learning how they think when it comes to manufacturing.
We found out why there was a 20mm stamped on the top of our 18mm carb. We found out why that carb was "strangled at high revs" as some old wise owl who gave a hoot told us..."all we needed to do was drill the air jet out."
Now Limey makes a passing comment and says, "I pull the air jet out of the Mikuni's cause the get in the way of making horsepower!" Lol
So we buy our first set of mikuni carbs and as we are driving down the road and they are in pieces in the back seat and Grandma is helping Zeke put them back together...priceless.
So we learn that a vm 22mm mikuni has no air jet and has the same slide as the vm20. They share the same internals but just have a different body. Kop told us that he had an interesting observation the 22 didn't really flow that much more cfm as dramatically as the 18mm-22mm jump.
Some questions I have for my son. What happens if we change the shape of the Venturi on the Mikuni to look more like the Venturi 8 of keihin. We have at least a mm to work with since the venturi is 21 and the slides are almost 23. what happens if we just remove the air jet from the Mikuni? What happens if we make the Keihin look more like the Mikuni at the waist and remove a mm on both sides of the eight...what will these mods do to our velocity flow on both and what is the OPTIMUM velocity flow for our engine?
How do we keep velocity up and increase flow...I know that is like asking "what is the airspeed velocity of an unladen swallow" :)
80MPH on a cb200 is not good enough it is called Do The Ton...and it is about to change.
What got us to 80...
17/35 gearing
iridium plugs
18mm carbs
cb750 velocity stack
racing timing chain
racing valve springs
dyna s
iridium indexed plugs
10w 40 partial synthetic
dyna 5 ohm coil
Taylor spiral copper core 8mm wires
What is about to change;
Peel 1 Airtech fairing
TZ250 td-1 Aero Tail
20mm carbs
deck height change -.5mm with a .032" copper gasket
lightened rocker arms
light exhaust porting
different racing springs
titanium retainers and washers
2 into 1 exhaust
steering stabilizer
fuel type change
eat lots of bacon
maybe drop the starter and shed as much weight as possible
Air jets are there to tailor the slope of the fuel curve. Bigger or smaller air jets change the amount of fuel that flows from the jets as load increases. Bigger air jets also help with atomization and some bikes have really poor atomization and need all the help they can get. That may help performance in some cases by making more fuel available to burn.
Fuel doesn't burn as a liquid, it burns the vapor on the surface on a fuel droplet. Smaller droplets increase the surface area for the same volume or mass of fuel. Break up the fuel better into smaller droplets and typically performance improves slightly - If that is a problem on that particular engine.
That's why we use BLEED type needle jets in 4 strokes - to help with atomization. Use a regular 159 PRIMARY type needle jet and you have big blobs of fuel and need air to break it up. Change to the right sized bleed type and a smaller air jet and get better results.
That's also a reason why some Hondas don't run well at low throttle with big VM mikunis fitted with 159 series NJs. Fuel comes out as big blobs and doesn't burn well and it's hard to jet correctly when the motor already has too much fuel but most of it isn't burning. The motor is running lean with too much fuel :-)
That's why car guys call them emulsion tubes.
We found some joules in our cl motor
After looking at Hansen Racings velocity stacks we thought we would give these a try on our Mikunis. They will fit a vm20, 22..and some mikuni flatsides so they will give us some flexibility. A Hansen pic for comparison. It also looked like hansen has the cam chain adjuster dialed in.
A velocity stack needs two things to work: Slight taper and nice radius on the intake. Those have both plus they are trick looking.
20mm carbs
2 into 1 exhaust
steering stabilizer
fuel type change
eat lots of bacon
Don't neglect the wheels. Alloy rims can shed a few pounds and also offer the chance to skinny up the tires. Thinner tires have less rolling resistance and so will also have an effect on the top speed of the bike. Higher PSI (if the tubes and tires can take it) will also help because deformation of the rubber against the road eats up a few joules.
will you revoke our DTT card if I tell you that we have been looking at moped wheels?
